Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
This project actually started October of 2010.. The build has snow balled quite a bit since then...
For more information on how this all started out click here:
https://ls1tech.com/forums/multimedia-exchange/1341381-vengeance-racing-tim-lynchs-twin-turbo-c6-z06-build-thread.html
After putting some miles on the combo in the link above Tim decided he wanted to build an engine that could support larger boost levels... The new engine consisted of the following:
427 cubic inch RHS
RHS Race Block- 4.125 Bore/Standard Deck
Lunati Pro 4" Stroke Crankshaft
Lentz Connecting Rods
Diamond Pistons/Rings
Custom Camshaft- MILD solid Roller
Jesel Solid Lifters
All Pro LSW-1 Cylinder Heads
Jesel Rockers
Jesel Solid Lifters
Jesel Rockers
Intake
FAST LSXR 102mm Intake
Nick Williams 102mm DBW Throttlebody
Fuel
Racing Solutions Triple Intank Fuel System
FIC 1500cc Hi Impedance Fuel Injectors
Clutch:
RPS Triple Carbon
Tick Adjustable Master Cylinder
RPS Triple Carbon
Exhaust:
B&B Fusion
DMH Dual Electric Cutouts
(At anything over 19psi we had extreme backpressure issues that were solved by adding the cutouts)
B&B Fusion
Boost Controller:
AMS 1000
AMS 1000
Turbos:
Precision 62mm Billet Wheel
Modified APS kit
Modified APS kit
Fuel:
93 Octane up to 15psi
VP Q16 up to 25psi
VP Q16 up to 25psi
Dyno Graph:
Run #13 had a much more aggressive "ramp" that would have allowed us to make a bit more power if we were able to keep the tires from spinning...
Run #12- we softened the ramp a bit to allow the boost to come on more gradual to get a clean pull..
This Z06 will average 34mpg cruising @ 80mph on the highway and drives about as close to stock as you can possibly get with the modifications it has.
Stay tuned for good WOT videos coming shortly!!!
Very nice!!
In what configuration are the precision 62s running this kind of power?
T4/3" with 65 or 66 wheel with which AR ???........if T3 then do you know pressure ratio?
What compressor cover?
Ball bearing?
Thanks for sharing!
DKT has a precision upgrade for the aps kits. 6262, 6266, and 6766( this little devil is going on my motor). Lol. Do a search there is a few post about it
But great job guys
But great job guys
According to this tread:
https://ls1tech.com/forums/forced-in...ossible-6.html
They are 1.06 exhaust housings, which could support ~1500 FWHP, but still with very high pressure ratios I imagine.......
E - S - B cover ??? my guess is 4" in, 2.5" out ?
Keep in mind that 1.06 a/r is still a t3, I'm just not convinced yet that it was thru a pair of t3 turbine housings unless he confirms it, that's all. The fact that it made 1343/1229 is just freaking awesome. But I'm with you, Im curious as well as to what were the specs on those turbos. But I really doubt that he would give that away for free.
That wheel will support that kind of power, you just have to crank up the boost. 25 psi on a big motor like that is intense on the dyno, and on the street. I gave up at 20 psi, and made 1080 on a cast 35R wheel. Add a billet wheel, 5 more psi, solid roller, better heads, and its very much doable, all through a T3.
There is NO way a T4 is going to fit in that realestate that the APS kit has.
Efficiency is key, and these guys did a good job!
Louis
Louis
