harsh 1-2 shift
Old 01-02-2012, 09:08 PM
astro11271984's Avatar
Default harsh 1-2 shift
just wanted to know if anybody else was having harsh 1-2 shifts durring light throttle on my second tranny and still have the shifting issue.
Old 01-02-2012, 09:13 PM
the_merv's Avatar
Has the car been tuned? How has the Trans been built?
Old 01-02-2012, 09:27 PM
TransAmWS.6's Avatar
Yes, as I'm rolling through campus going 10-20 mph, it feels like I've been rear ended when it shifts from 1-2. It seems like a fairly common thing with the 4L60E's in these cars, my friends '99 Trans Am does it as well. As long as it's not slipping or hesitating, everything should be fine with it.
car was doing it prior to the tune trsnny is a built 4l60e with stage 3 shift kit but was doing it while everything was stock form and after new trans mount
Old 01-02-2012, 09:42 PM
DOG-TWO's Avatar
My 98 TA has a fairly hard 1-2 shift when puttin' around. It's nothing to worry about.
Old 01-02-2012, 09:52 PM
cool ive gotten pretty use to it but always in the back of my mind ill kill my rear end
Old 01-02-2012, 10:04 PM
the_merv's Avatar
Na that wont kill the rear..lol.
Old 01-03-2012, 08:49 AM
chris95lt1ta's Avatar
Mine is doing it as well but it also gets stuck in 3rd gear.
Old 01-03-2012, 09:06 AM
72blownvert's Avatar
Did you scan for codes? there could be an 1870 code stored in the computer. If it is real harsh at light throttle and it feels like something can break there is a problem for sure.
Old 01-03-2012, 11:45 AM
no codes thrown but it always feels like im going to chirp the tires going light throttle.
Old 01-03-2012, 12:25 PM
jimmyblue's Avatar
Some faults will make it shift hard & early, and may
not set a code if intermittent enough. The shift kit
usually firms up shifts and maybe this was excessive.
Especially if somebody also upped shift pressures in
the "street tune".
If you can look at force motor current, see if it is
bottoming to 90mA or 0mA (commanded full pressure
during shift). That would implicate a fault if it's at
part throttle.
Old 01-03-2012, 02:50 PM
gofasterdammit's Avatar
check to see if your 1-2 accumulator piston or spring is broken. the 1-2 usually does have a little bump to it but a bang is different. if its a bang then check that out first.
Old 02-20-2012, 08:22 PM
carpenb52's Avatar
Mine was doing the same thing. harsh shift from 1st-2nd and shifting into overdrive sometimes. I just took it to the dealership and they said it was the 1,2 accumulator and that also should fix the overdrive problem too. i should know in the next day or so.
Quick Reply: harsh 1-2 shift
