Best size tire- 17 inch rims
Old 12-20-2011, 11:38 PM
Sladester2's Avatar
Default Best size tire- 17 inch rims
What size tires do you guys think look the best on a Trans Am with 17 inch rims? What is the lowest profile you would go and what is the thickest? Right now I have 275/40s on them but looking for more options
Old 12-21-2011, 05:00 AM
MasterTomos's Avatar
Depends on the width of your rim? Tire sizes coincide with the width and height of a rim.
For example on a 275/40/17 tire=
275mm wide, with a side wall that is 40% the height of the width of the tire (so 40% of 275=your sidewall height), for a 17 inch rim.
Various widths will best suite a certain width of rim. With a smaller rim, you can get away with more sidewall and still achieve near-factory entire wheel height.
Old 12-21-2011, 08:47 AM
lees02WS6's Avatar
Stock width? (17"x9")
275/40/17
Which also good on 17"x9.5" wheel.
Old 12-22-2011, 08:26 AM
CamaroSS27's Avatar
Ya I run 275/35/17
Old 12-22-2011, 07:16 PM
whytryz28's Avatar
245 front
Old 12-22-2011, 07:52 PM
Sladester2's Avatar
Originally Posted by whytryz28
245 front
245/40/17 and 275/40/17 on back, would that make stance look pretty good?
Old 12-22-2011, 08:05 PM
whytryz28's Avatar
You wont really notice a change in stance with that combo, I just personally dont see a need for anything larger then 245 fronts unless you auto x
Old 12-22-2011, 09:23 PM
JimMueller's Avatar
I like the same size on all corners. On 17x9.5's, I've used 265, 275 & 285 in a 40 series. The narrower tire was more responsive, the wider was a bit more confortable. They should all be fine on a 17x9.
Old 12-23-2011, 01:32 AM
Sladester2's Avatar
so 275 40 should be fine all the way around?
Old 12-23-2011, 02:29 AM
1996firebirdformula's Avatar
Yes that's what stock ws6 and camaro ss come with 275s allway around.
Quick Reply: Best size tire- 17 inch rims
