Z-Pack vs Alto Reds
Old 12-15-2011, 09:36 PM
95_transam_lt1's Avatar
Default Z-Pack vs Alto Reds
for the 3-4 clutch (in the input drum) would it be better to get a zpack over a set of alto red clutches and steels? i have a set of altos in the trans now but wouldnt be against getting a zpack instead. its a 4l60
Old 12-15-2011, 10:44 PM
01ssreda4's Avatar
My builder recommended the Zpak.....so that's what I had him put in.
Old 12-16-2011, 09:27 AM
Bullit95T/A's Avatar
Default Use this it works.From www. transmissioncenter.net
√ #14-8. PATC - Alto RedEagle PowerPack for the 700R4 / 4L60E 3-4 clutch. This clutch set comes with 8 RedEagle clutches, 7 Kolene full thickness steel plates and 1 thin backing plate. This is a 33% increase in the clutch apply area.
Old 12-16-2011, 10:26 AM
lt1pwr1's Avatar
If you go Alto, just make sure you get FULL thickness steels. You'll have less friction plates but you don't want to get thinner steels as they tend to warp. This is based on my research, I'm no trans builder.
As far as Z-pak, I bought my 99 GMC Sierra with 140K with the trans shot. The trans guy at my dad's dealer rebuilt it for me and I had him put in the Z-pak and it has performed flawlessly for 25K miles (have 165K now). I know a truck application is much different than a high HP car but I do a ton of towing with the thing and I've been very happy so far....we will see I guess. I'll be happy if it lasts 100K on the rebuild. I also had a wider 2-4 band, and Sonnex Super hold 4th gear servo as well as Corvette servo for second.
Old 12-16-2011, 11:11 AM
LS1Tech Sponsor
performabuilt's Avatar
I have used both I like the zpack better myself as its proven itself very well over the years
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-17-2011, 04:39 PM
ramairws6's Avatar
Just use the high energy Borg Warners and be done.....
Old 12-17-2011, 07:39 PM
sjsingle1's Avatar
ok.......so what is the difference between the HE BW and Z pak?
Quick Reply: Z-Pack vs Alto Reds
