LS1 Catch Can
Old 12-05-2011, 03:24 PM
DBShocker's Avatar
ugh there is so many different ones i cant decide which one to get. lol because i will want one with instructions, hoses, and right brackets and everything.
Old 12-06-2011, 11:18 AM
BlackLS1Bird's Avatar
Here is where i got mine. It comes with the bracket, fittings, and instructions. I cant remember if the hoses came with it or if I got a short section of hose from the auto parts store. I had already deleted my EGR so it bolted right up to my passenger side cylinder head. Havent had any smoking or oil burning issues since installing it.
http://www.ws6project.com/user_stor/...pcv-catch-can/
Old 12-06-2011, 11:24 AM
DBShocker's Avatar
do u have any pics of urs on the car im thinking ill prob go ahead and get it in red also. i have also deleted my egr when i got my new headers so that should be fine.
Old 12-06-2011, 02:58 PM
Ill take some and post them up tonight.
Old 12-06-2011, 03:20 PM
DBShocker's Avatar
alright thanks i guess i should ask where should i get hoses for the can and what kind to get that are best for oil and all.
Old 12-06-2011, 03:33 PM
99Bluz28's Avatar
Just ask for some Oil/fuel line hose at your local auto parts store, they'll know what your talking about. You will probably need 3/8" ID oil/fuel hose, unless your instructions say otherwise.
IMO, Take a hard look at the RX cans(I run one in my car), they seem to do a better job of trapping the oil vapors than a lot of the small CC do.
http://www.coloradospeed.com/index.p...ducts_id=13737
Old 12-06-2011, 06:39 PM
Here are the pics of my catch can.
Old 12-06-2011, 11:00 PM
mean_greenZ's Avatar
Attachment 329265
Attachment 329266
Why are you filtering your fresh air line?? That's not where the oil gets sucked from.
Old 12-06-2011, 11:18 PM
double_z's Avatar
I just ordered a saikou michi catch can. Look forward to installing it and cleaning out my throttle body.
Old 12-07-2011, 06:43 AM
Seemed wierd to me too, but that was how it said to hook it up in the instructions and all of the smoking out of the exhaust and oil residue in the throttle body/intake has stopped. That just figures. I swapped the A4 for a T56 in my driveway on jack stands and had no issues, but messed up the damn catch can. Sometimes its the smallest things that get you.
Old 12-07-2011, 07:36 AM
Kleeborp the Moderator™
MeentSS02's Avatar
There is some oil that will pass through that line, especially if you are really hammering on it. I have a can for the fresh air line and one for the valley cover - the valley cover can catches a lot more than the other, but the fresh air line certainly isn't dry (at least not on mine).
Old 12-07-2011, 08:56 AM
  #32
I'll probably just put a "T" in the line and run both through the same catch can. Cover all the bases.
Old 12-09-2011, 10:41 PM
  #33
DBShocker's Avatar
well i just ordered the Rx catch can so ill see how well it actually works, i was also looking at the Elite Engineering catch can and it seems pretty good but i guess im stuck with the Rx one for now so ill let you guys know how it goes
Old 12-12-2011, 07:33 PM
  #34
mebuildit's Avatar
I've been thinking about using these guys for a catch can set up. http://store.radiumauto.com/index.ph...id=15&parent=0
Old 12-16-2011, 01:27 PM
  #35
DBShocker's Avatar
here are some pics of the Rx catch can that i just got this mourning. dosent look 2 bad and was a bigger can that it looked in the picture which is nice.
Old 12-16-2011, 02:08 PM
  #36
joecar's Avatar
No, this won't work
(all this does is directly suck air from the TB instead of the crankcase).
Old 12-16-2011, 09:34 PM
  #37
DBShocker's Avatar
ok well after driving my car to and from work today my check engine light came on, anyone else have this happen after installing their catch can?
Old 12-22-2011, 10:02 AM
  #38
DBShocker's Avatar
Never mind about the check engine light i remembered i forgot to plug the sensor back into my air filter when i took it off to look into my intake which was saturated with oil :/
Old 12-22-2011, 01:59 PM
  #39
99Bluz28's Avatar
That good to hear it was something very simple.
Old 12-23-2011, 03:03 PM
  #40
Thule's Avatar
i just hafe breathers, havn't noticed any problems with the oil, no moisture and it does not burn, but i do want to install a can,
i hafe ls1speed polished valve covers, and need to make the system from the ground,
can i use the TB alone to suck up the oil?
Quick Reply: LS1 Catch Can
