Po420-po430
Po420-po430
Hey guys, got the ses light on codes are po420 and po430. Car starts and idles normally. but under acceleration i feel some hesitation but usually comes out of it in the higher rpms. could this hesitation be caused by bad cats? I have read alot on here about maf's being dirty/bad causing similar problems but the codes or po420 and po430. car doesnt fall on its face or anything but a noticeable hesitation is felt under acceleration. Car is 00 trans am m6 bone stock. im putting long tubes and ory soon but thought i would ask if hesitation could be related to po420 and po430 codes. thanks!
LS1Tech Administrator
Received 1,493 Likes
Inefficient cats won't cause any hesitation or driveability issues at all, just incresed emissions which is what the codes directly indicate. On the other hand, if the cat material has melted or broken up and become clogged, that would certainly cause performance issues.
The fact that you mentioned this...
It never hurts to clean up the MAF. Lots of little issues have been traced back to dirty MAFs.
Internet Mechanic
Agreed, also consider possibly either a Dirty MAF, Bad Cats, OR o2's need replacement.
If the up stream and down stream do not jive, this is what triggers the code too. It could be due to clogged cats, or the sensors are going and are considered "lazy". Also driving WOT or part throttle can be effected and generally when the car goes to WOT its not looking at the o2 sensor reading so there should be no reduction in performance.
IMO I would consider if they are original is to replace all of them at the same time and clean the MAF, from there if no change, then its the CATS. It kinda sucks as one of the o2's are pretty far up there and you may have a better change removing the cat to get at it (free labor.... ) so you may just do it all at the same time.
Remember to clear the codes out with a scanner and do so many drive cycles to re set monitors incase you have a ODBII scanner emissions requirement.
ok I'll just replace them all this weekend went ahead and got bosch o2s should be in tomorrow. if this doesnt get codes off then i wont be replacing the cats since i plan on putting some tsp long tubes on this winter with ory. One ? thought tonight i was driving home from work and i decided to lay in to it a little on the interstate and the ses light started blinking for a few secs. now i havent scanned codes yet but if i am not mistaken that is indicating a misfire correct? that would not have anything to do with 02's or cats would it? i wouldnt think so...but It got new wires and plugs 2 months ago. thanks for any input
Internet Mechanic
Flashing SES light does indicate a mis-fire. Which can cause O2 sensors to go out of wack as if one or more mis-fire the exhaust mixture will be different and can throw off the difference each O2 reads.
I would pull all the wires, plugs, re inspect, re gap, re install.
What plugs / wires did you go with??
Also to mention once you do the o2's IF there is an issue it takes so many drive cycles to reset the monitor so IF its going to throw a SES, it may not do it immediately. Just a FYI.
So if I was looking at this car, this would be my check list to start.
-Clean MAF
-Replace all o2 sensors
-R & R spark plugs and wires, inspect and decide what to do.
-Clean MAF
i ordered the msd wires and ngk tr6 combo from texas speed think i paid around 80 bucks for them also got some lts and true dual exhaust. will my bosch 02s i just bought work with the lts ? and im deleting cats with lts and ory will i continue to throw light for cats or can a tuner take care of that? I am putting it on a dyno when this is finished because i have a torquer v3 going in as well and a ls6 intake. I will pick up a can of that maf cleaner from advanced and clean the maf. i know this is off subject but you guys think this is a good combo? already got the moser 9in coming and sub frame connectors. Car will never see track ever. Thanks a million guys for all the input.
those plugs and wires seem to do ok? anyone else running them?
