Rear sway bar problem.... (with pictures)
Old 11-02-2011, 05:26 AM
Blue2002SS's Avatar
Default Rear sway bar problem.... (with pictures)
After I lowered my car I started getting a creek and groaning noise from the rear end when it went over a speed bump. So I got looking under the car and noticed the sway bar end links were not straight and appeared to be to long. So I got some energy suspension end links 1 and 5/8 inch and they still appeared to be to long so I chopped 1/4 inch off the spacer to make them 1 and 3/8ths. Tried installing them yesterday and It seems like the sway bar is to far forward here are some pictures, any ideas or is this normal?
Old end link:
I also noticed when the drivers side of the sway bar was touching the mounting bracket the passenger side had almost an inch of room left, so I thought the sway bar was bent. I took the bar off to check and its not bent....
Old 11-02-2011, 07:50 AM
UMI Sales's Avatar
Hey Blue. Is that the original bar for that car? Has the car been wrecked? End link length is sometimes a concern with our customer cars depending on what all is done to it. What concerns me is the difference side-to-side. And you say the bar is symmetrical?
I'm wondering if you have a bent trailing arm?
ramey
ps good job on the pics, helps a lot
Old 11-02-2011, 07:53 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
The creaking and groaning noise more than likely came from the sway bar bushings themselve not the end links. I bet if you spray some WD-40 on the front an rear end link bushings the noise will go away temporarily go away which will show that the sway bar bushings are the culprit. I have never personally seen a end link make a creaking or groaning noise, especially a stock one.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 11-02-2011, 05:01 PM
Dark_Pheonix's Avatar
1. By cutting the spacers the bushings are not compressing properly now.. And will be loose. 2. Let's assume when you're jacking up the reared, it's level. (you're not lifting one side at a time)
3. The bends in the sway bar should follow the axle.. This will tell you if it's centered or not.. 4. The geometry causes the sway bar to move in an arc, meaning the links won't be straight all the time, depending on the position of the axle.
5. Make sure the lca's and phb are lubed good, since you changed the position by lowering the car it could be on a dry spot..
Hope this helps
Old 11-02-2011, 05:10 PM
Blue2002SS's Avatar
ramey
Yes original sway bar, car has never been wrecked..... actually never even gone over a speed bump fast.
That was my idea because the car was lowered 1.5 inches I should get shorter end links to match.
The sway bar is symmetrical.
Old 11-02-2011, 05:52 PM
Blue2002SS's Avatar
Hope this helps
1. I made sure there was plenty of thread on the long bolt so the nut would still tighten down properly before I cut the spacer, so that should not be an issue.
2. It is sitting on rhino ramps, so should have equal weight on the rear tires.
3. Its centered
4. I rotated the sway bar through its arc and It seems like there is no point where it would properly line up.... they only way to make it line up would be if the entire axle were moved to the rear of the car about 3/4 of an inch.
5. I will lube them, thanks for the ideas and help
But this is my question, Is this normal? or is something on my car different from most?
Old 11-02-2011, 10:48 PM
joecar's Avatar
Do you have a pic from behind/under/center looking forward at the sway bar and axle...
Old 11-03-2011, 07:57 AM
What about your torque arm? Is it adjustable? Broken? Bent? If so it could throw off the pinion angle and push the sway bar forward
Old 11-03-2011, 08:08 AM
99 WS-sick's Avatar
if u didnt put an adjustable pan hard bar on when u lowered it, then the rearend will be offset about 3/4 inch, also u need lower control arm relocation brackets to realign the rearend with the center of the fender wells. just lowering springs is only %25 of lowering the car. without the other items the suspension will not perform correctly.
Old 11-03-2011, 08:10 AM
hopefully this works.. heres a pic for comparison
Old 11-03-2011, 02:57 PM
HAZ-Matt's Avatar
Can't see the picture.
You may have needed to have just left the length alone. Many times the tab on the sway is not going to be perfectly parallel to the body of the car at ride height, not does it matter a great deal. As long as you can get the bolt in and can tighten it until the bushings are snug then it should be fine.
If you try to shorten the distance it makes it more difficult to even line them up, as already mentioned earlier, and as you saw yourself.
Old 11-04-2011, 05:19 AM
Blue2002SS's Avatar
I have LCA relocation brackets and I bought the adjustable pan hard bar, but the car was centered after lowering it. So the bar is just sitting in my garage now......
Everything seemed to work fine, except for the strange noise going over speed bumps, so I'm just going to put it back together with the new end links and see what happens. Thanks for everyones ideas though
I was hoping I could see some other setups to compare how much of an angle their end links are at?
Old 11-04-2011, 04:11 PM
99 WS-sick's Avatar
it may not be the end links, take the rear sway bar off and go over a speed bump an listen for the noise. (dont drive at high speeds without swaybar)
Old 11-04-2011, 05:31 PM
HAZ-Matt's Avatar
Driving without the rear bar shouldn't be as bad as driving without the front bar...
At any rate, yeah you could drive it without the bar and see if you get the noise. I don't think it is the end links. I understand what you expected to see, but with my aftermarket bar it is more or less like your top picture at ride height and the bar is not making noise. The only thing at the rear of my car that makes noise usually are the rod ends in my watts link.
Old 11-05-2011, 03:48 AM
Blue2002SS's Avatar
Well I got the rear sway bar back on tonight, everything seems to fit ok. Just those crazy end links.
Unfortunately I cant take it for a drive until I get this round of mods done
Old 12-21-2011, 01:13 AM
TruBloodTransAm's Avatar
I just installed my rear sway bar, everything went on smooth.
Old 08-14-2013, 01:04 AM
Empatho's Avatar
Bringing this back from the dead. Op did you ever find a solution for this, because mine is doing the same thing and d squeaking is getting annoying. I have strano sway bars and my end links on the rear are not going straight down, they have an angle also.
Old 08-14-2013, 03:54 PM
NinetynineredZ's Avatar
I may be looking at this too simple but, couldn't you just rotate the bar towards the back of the car to drop the height of the bar ends?
Old 08-14-2013, 08:56 PM
Empatho's Avatar
Ill try that, but was a pain in the *** when I did it with the end links already on though. I guess I gotta try it without the end links.
Old 08-14-2013, 11:55 PM
Empatho's Avatar
Went to take a look at the rear sway bar and I can't move it back.
Quick Reply: Rear sway bar problem.... (with pictures)
