Heater hoses
Old 10-26-2011, 08:06 PM
O2Form's Avatar
Default Heater hoses
How many of you had their heater hoses fail? The two small hoses are starting to feel soft but don't look cracked or anything. I tried finding replacement hoses but so far only the dealer sells them.
Old 10-27-2011, 09:46 PM
LS6427's Avatar
I put this on mine because they were getting mushy and soft. Razor knife a little bit off the longer end and it fits perfect.
http://www.summitracing.com/parts/DAC-87629/
This guy sells high quality used ones: I think $40.00
http://www.tacreationsusa.com
http://www.tacreationsusa.com/images.../ls1heater.jpg
Brand new GM hoses....$137.00
http://www.ebay.com/itm/98-02-LS1-Ca...d#ht_757wt_698
Used: $75.00
http://www.ebay.com/itm/98-02-CAMARO...a#ht_500wt_715
Or just buy 5/8" and 3/4" heater hose and run them yourself for $20.00. Wrap them in heat tape where they run along near the exhaust manifold piping.
Old 10-28-2011, 08:03 AM
redbird555's Avatar
http://www.ls1.com/forums/f6/water-h...sembly-151001/
heres what I did it cost me about 20 bucks and it unless you know what your looking for one couldnt tell it wasnt factory
Old 10-28-2011, 10:35 PM
LS6427's Avatar
I was thinking to just remove all the factory stuff, the metal lines. Then just run two new heater hoses.....use a couple U-clamps to keep them both against the body where it runs up along the strut tower. Wrap the hoses real good with heat wrap ion that area. So no more metal hoses/lines. All rubber. Then just 4 clamps instead of 8.
Old 10-30-2011, 10:30 PM
redbird555's Avatar
You could do that I just saw this a cleaner solution and it looks factory I haven't had any problems with the clamps leaking and you really on see the 2 on the engine vlock
