steering wheel shakes at 55mph
Old 09-21-2011, 04:21 PM
02ws.sik's Avatar
Exclamation steering wheel shakes at 55mph
My steering wheel shakes at 55-65mph. What is this? Is it my front end out of line? Or something else?
Thanks Justin
Old 09-21-2011, 07:58 PM
02ws.sik's Avatar
Come on some one has too know how to help
Old 09-21-2011, 08:05 PM
ULTIMATEORANGESS's Avatar
are your tires properly balanced?
Old 09-21-2011, 08:08 PM
07darknight's Avatar
yea i would get your tires balanced
Old 09-21-2011, 08:12 PM
02ws.sik's Avatar
They are maybe a month old they cam from oe wheels
Old 09-21-2011, 08:16 PM
do you feel any vibration under your feet?
Old 09-21-2011, 08:25 PM
Ruthless909's Avatar
It can be that maybe one of the weights fell off the wheels.
Happened to me before
Old 09-21-2011, 08:31 PM
black-v's Avatar
if its in the steering wheel its the fronts need balance if its in the seats the rear needs balance
Old 09-21-2011, 08:43 PM
02ws.sik's Avatar
Sorry it was like this with the factory rims too. Its only in the steering wheel. so whats that?
Old 09-22-2011, 07:41 AM
ccrook19's Avatar
check out your tie rods.. it kinds sounds like a inner..
Old 09-22-2011, 09:39 AM
Save the manuals!
wssix99's Avatar
If the vibration goes away faster than 65, then both of your sets of wheels are out of balance.
Regardless, your steering wheel is fine. Something in your suspension is messed up. (You can even sometimes feel vibrations coming through the rear in the steering wheel.)
Old 09-22-2011, 11:35 AM
JohnS Z28's Avatar
mine vibrates when braking at high speeds only...like 85, but not when im moving, i can get 100-120...on a closed course...pretty comfortably.
Old 09-22-2011, 07:21 PM
02ws.sik's Avatar
Going to get it fixed tommorow.
Old 09-23-2011, 05:42 PM
02ws.sik's Avatar
Well ntb tells my dad the drivers side wheel baring is bad so we get a new one and replace it. And i went back and they couldn't get me in so 9 am tommorow i will get the front end aligned because it pulls to the right and see if that stops the shimmy and shake in the steering wheel. If that doesn't do it i will see about getting my wheels balanced well checked because they should be balanced. They have new tires on them. What else could it be its not the tie rods or ball joint the guy and my dad checked.
Old 09-23-2011, 09:48 PM
Bjorn20's Avatar
wheel bearings do not cause vibrations
worn front end parts do not cause vibrations
alignments have nothing to do with vibrations
If you have had a vibration since day one and just got new tires, I would suspect that those wheels are bent. But either way steering wheel vibrations are normally from a tire/wheel out of balance.
vibration while braking at high speeds is a warped rotor. Usually the front rotors. The rear brakes can get warped rotors too, they are just harder to diagnose, depending on how the parking brake is setup.
Old 09-23-2011, 09:58 PM
02ws.sik's Avatar
The bearings were worn so we replaced them. We have had other cars shake in the steering and get the front end aligned and it stops. The tires and rims are about a month old with about 1500 miles on them. The stock rims and the oe wheels shake the steering wheel. its has 64000 miles on the car and i dont think the rims are bent. It has play in the steering too. So bushings in the front end wont cause the steering wheel to shake then what can it be???
Old 09-23-2011, 10:26 PM
Bjorn20's Avatar
I can understand if the wheel bearings were worn to replace them, but the only reason they mentioned that was to make a quick sale.
Unless your alignment is waaaaaay off and you can visually see the tire angled way out, I cannot see an alignment issue causing a vibration.
If the tires/wheels are properly balanced, new tires (assuming the tread isn't cupped/separated) and you still have a vibration just cruising, the only thing I can think of would be to look into balancing the drive shaft?
Shitty tires out of the box can easily cause a steering pull, I saw that all the time. Although they normally don't cause a vibration right out of the box, but I wouldn't rule it out.
I don't know, it is sometimes hard to diagnose things of this nature over the internet without actually being in the car to feel the vibration and to determine the type of driving conditions the vibration occurs in.
Worn bushings will just cause a squeaking noise or sometimes a "clunk" over bumps, because they allow the parts to move around when they should be nice and solid with the bushing doing its job.
Old 09-24-2011, 12:30 AM
JohnS Z28's Avatar
^^^We appreciate the knowledge.
Old 09-24-2011, 07:06 AM
02ws.sik's Avatar
Pirelli p zero rosso are what is on the car. I would think that is one of the best tires if not the best.
Old 09-24-2011, 07:08 AM
02ws.sik's Avatar
And saying the wheel bearings being worn my cousin was the one working on at ntb with another guy. I hope the cousin i trust wouldn't do that.
Quick Reply: steering wheel shakes at 55mph
