Heater hose routing
Old 09-13-2011, 06:41 PM
tsnow678's Avatar
Default Heater hose routing
I have two ports coming out of the side of the LS1 water pump. One is larger than the other. I need to know which one is the supply and which one is the return. I am installing the Vintage Air system and need to know how to route my hoses. Any help would be greatly appreciated. Thanks
Old 09-13-2011, 07:13 PM
gMAG's Avatar
tsnow, this should help!
https://ls1tech.com/forums/conversio...-question.html
Old 09-13-2011, 07:49 PM
lizeec's Avatar
Small outlet is supply, large outlet is return
Old 09-13-2011, 07:53 PM
tsnow678's Avatar
Originally Posted by gMAG
You are the man! Thanks that was a big help!!
Old 09-13-2011, 07:54 PM
tsnow678's Avatar
Thanks lizeec!
Old 09-14-2011, 01:15 PM
usmcz28's Avatar
Awsome, good info to know
Old 09-14-2011, 03:57 PM
Rocketrod's Avatar
x2...
Old 09-14-2011, 10:12 PM
bczee's Avatar
most system will usually be small is pressure and larger is return. Take a look at your radiator, power steering and AC system.. Easy to remember...
Old 09-15-2011, 04:11 AM
tsnow678's Avatar
You know I never put the connection together before starting this thread. Its funny how you change out all these lines over the course of years and never realized why one was larger than the other. Thank bczee and all of the others that helped out. I have my routing solved onto the next issue!!! Thanks again
Quick Reply: Heater hose routing
