5.3 cam choice
Old 09-10-2011, 10:00 PM
cooljoe900's Avatar
Default 5.3 cam choice
I just got a 5.3 LM7 out of an 04 Silverado and Im looking for a cam. Im building a carbed motor that is going into a S10. The truck is a street truck but I like a choppy idle but something that is still driveable. These are the cams I found so far so let me know what you think will be the best and if I will have to do any mods for it (springs ect.)
- 212 intake 218 exhaust @ .50, 551 551 Lift on 114 LSA
- 03 LS6 Vet Cam
- Intake- 196 degrees of duration at .050" with .467" of Max Valve Lift.
Exhaust- 201 degrees of duration at .050" with .479" of Max Valve Lift
Any other suggestions on a cam choice?
Old 09-11-2011, 07:45 AM
Darkman's Avatar
I would look at some of the EPS cams from Engine Power Systems for 5.3s and talk to Geoff Skinner there.
Old 09-11-2011, 08:27 AM
PREDATOR-Z's Avatar
From Lunati
60519** 2400 - 6800 CAMSHAFT, GM LS VHRX278-08CX 278/282 227/231 .651/.651 108/108
60520** 2800 - 7000 CAMSHAFT, GM LS VHRX286-08CX 286/294 235/243 .651/.651 108/108
60521** 3200 - 7200 CAMSHAFT, GM LS VHRX298-08CX 298/306 247/255 .651/.651 108/108
60522** 3600 - 7500 CAMSHAFT, GM LS VHRX306-08CX 306/314 255/263 .651/.651 108/108
Old 09-11-2011, 01:30 PM
nastychevelle's Avatar
any cam you choose is going to need new springs and pushrods.
a tr220 seems to be a popular cam on the truck boards. But depending on weight you could go a little bigger.
is the vehicle an auto? torque converter is another thing to consider. i wouldnt run any cam with a stock converter.
Old 09-11-2011, 06:24 PM
cooljoe900's Avatar
Yeah the truck has a 700r4 with a 2800 stall converter. Its right around 3000 lbs.
Now when you say I need to replace the push rods, do you mean with a more heavy duty rod or a different length depending on lift and rocker ratio? I'm staying with the stock 1.7 rockers if that helps.
Old 09-11-2011, 11:45 PM
PREDATOR-Z's Avatar
You'll need hardened pushrods. Length to be measured once cam installed, could be different length depending on cam's base circle.
This is what I recommend:
224/230 .581/.590 111+2 LSA
Old 09-12-2011, 01:09 AM
01ssreda4's Avatar
TR224 or 224r gets my vote.
Old 09-12-2011, 01:14 AM
yelo04goat's Avatar
LS6 cam can be had cheap and sounds good in a 5.3 buddy had one in his whippled 5.3 72 jimmy
Old 09-12-2011, 03:38 AM
jermzz's Avatar
+1
best cam I ever owned on stock cubes.
Quick Reply: 5.3 cam choice
