110 octane and now car is running like crap
Old 09-03-2011, 03:43 PM
SuperCamaroSS's Avatar
Default 110 octane and now car is running like crap
put 110 octane in the car and almost immediately started idling funny. In park while running idle would go up and down and then stall out. At a stop light when i would come to a stop it would die out. car ran perfect on 100 octane and I still have about 30% of the 110 octane left in the tank. anyone have any ideas? car ran perfect before i placed 110 in it. Thanks
Old 09-03-2011, 04:58 PM
gs462's Avatar
Was the 100 unleaded? I'd Look at the o2 sensor leaded fuel can kill them quick.
Old 09-03-2011, 09:11 PM
my buddy who took me to the Citgo said he is pretty sure it is unleaded but he could be wrong. pcm is tuned to pass emissions so I am not sure if an SES light will come on or not. I know that an SES light does turn on for an o2 sensor. gonna have to use a scanner i guess to see if o2 sensors are working. do you know what diagnostic tool/ scanner works best? might have to invest in one. Thanks.
Old 09-03-2011, 09:26 PM
mbaker3's Avatar
Go to this gas comparison link - it shows that Citco 110 "is" leaded. ( I have no idea how accurate this site is).
http://www.smithtex.com/racing/fuelcomp.html
Old 09-03-2011, 09:33 PM
interesting...thanks. I am just shocked that it would damage my o2 sensors that fast. I had no idea. (then again I am no genius when it comes to cars). I wonder if this has happened to anyone else.
Old 09-03-2011, 11:34 PM
gs462's Avatar
Been drag racing since the late 80s and I've never seen 110 unleaded, not
saying it doesnt exist but i've never seen it. Also in my Turbo regal It has killed the sensor instantly more than once, like you said thats why I suggested it.
Old 09-03-2011, 11:44 PM
Fbodyjunkie06's Avatar
If using leaded race fuel with 02's you MUST put some unleaded fuel in it. If you put say 5 gallons of 110 I'd say at least one gallon of 93 must be used to keep it from killing the sensors.
Old 09-04-2011, 06:51 AM
I had aboutt a 1/4 tank of 100 octane when I put the 110 in. Didn't know about needing 93 in it. Thanks guys, you have all helped a ton.
Old 09-04-2011, 07:19 AM
Bluestreak's Avatar
If the fuel was leaded, you may have coated the sensors and ruined them. Find a scope, probe the O2 sensor return circuits to the PCM. Make sure they're switching between 0.1-0.9v rapidly. If not, there's your problem. More than likely that's not it, as an O2 out of range or slow switching would pop an SES light.
Old 09-04-2011, 08:03 AM
Old Geezer's Avatar
I wonder how much of that 110 is sold from that station...You may have gotten a load of nasty fuel. That would be more likely than an instant O2 failure..
As for adding 93 to prevent O2 failure??? Only may delay the inevitable, & dilute the octane you were after to begin with.
Old 09-04-2011, 09:04 AM
My buddy filled up his Camaro at the same time as I did from the same station and his car ran fine on the 110 and still is running fine so I doubt it was a bad batch of gas.
Old 09-29-2011, 04:18 PM
Dirty Vegas's Avatar
VP C10 is unleaded 110 octane.
Old 09-29-2011, 04:57 PM
Higgs Boson's Avatar
just use MS109. that's what i use when i spray.
Old 09-29-2011, 06:01 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Wait!!!! A gas station has 110 octane fuel??? At the pump??? We can't even get 93 around here! Pics or it didn't happen!
And I have to agree with the poster above me. Run VP Fuels! Either MS 109, or VP100 aka Street Blaze 100. Unleaded and oxygenated. Good stuff!
FWIW....
MS 109 is 109 Research octane, and 101 Motor octane.....105 R+M/2 (At The Pump)
VP100 Is 104 Research, 96 Motor, 100 Pump
Used to sell VP Racing Fuel, so I'm kinda biased.
Old 09-29-2011, 07:19 PM
Hope you tuned correctly for that. You can't run MS109 without fattening up your tune.
Old 09-29-2011, 09:03 PM
gs462's Avatar
And as I stated I've never seen it.
Quick Reply: 110 octane and now car is running like crap
