LS1 Motor mount plates, prints?
Old 08-29-2011, 08:45 AM
ONyX711's Avatar
Default LS1 Motor mount plates, prints?
Does anyone have the dimentions for motor mount adaptor plates? There was 2 pics in one of the FAQ's but both links were no good. Im going to make a set and a print would be gratefull. Also any first gen camaro guys here have the dimentions for the 4 sfront sub frame mounts, im goin to spin up a set of aluminum ones once i get the dimentions. Need to change them while I do the ls1 swap.
Thanks guys
Old 08-29-2011, 09:54 AM
TomM's Avatar
This one?
T,
Old 08-29-2011, 10:58 AM
ONyX711's Avatar
That will do thanks
Old 02-12-2012, 05:11 PM
94krawler's Avatar
Originally Posted by TomM
This one?
T,
Thanks! This will save me some time
Old 02-13-2012, 08:01 AM
MCMLXIX's Avatar
Is there a drawing like this for the heads?
Old 09-06-2012, 10:09 PM
1fastmofo's Avatar
anyone have the info for the hardware?
Old 09-06-2012, 10:20 PM
IMPALAMAN1's Avatar
Default What position
does this design set the motor at?
Old 09-10-2012, 10:10 AM
kwhizz's Avatar
The 3.125 dimension on the motor plate drawing is incorrect......It should actually be 3.070.......(78mm)......ask me how I know......LOL
Ken
Old 10-27-2012, 12:20 PM
turbofrank's Avatar
Ken
How do you know?
Old 10-28-2012, 02:04 PM
kwhizz's Avatar
Originally Posted by turbofrank
How do you know?
I made a set to those dimension........then when they didn't fit I made them over after checking the block and getting the correct numbers........
Old 10-30-2012, 01:19 AM
454ragtop's Avatar
Strange that print shows the holes at 9/16", seems way big to me. Bolts are either 10mm or 3/8", both of which are smaller than 7/16". Also, wondering where these mounts will place the bell housing flange in relation to a traditional small block? Also, just noticed it calls for the third hole from the left, at the top, to be countersunk for a flat head bolt, pretty sure it needs to be the second from the left, as that one will be underneath the motor mount.
HTH, Jim
Old 10-30-2012, 08:01 AM
Doug G's Avatar
I took a LS MM and traced it out, then measured 1" forward (engine set-back) and used a SBC 3 bolt MM and traced it out.
Then I just bought a pair off Ebay for $40 but they came PC'd and with bolts.
Anyway....
Old 10-30-2012, 09:42 AM
hookemdevils22's Avatar
yeah, that design is wrong. I addressed it in the "LS1 Swap FAQs" thread. You can see where the countersink should be in S&P's instructions (second photo down).
Old 01-17-2014, 07:00 AM
TableLeg's Avatar
For anybody else like me who might look for this info.....
The hole spacing is incorrect as pointed out by Kwhizz, I too have just had my laser cut plates back to find they don't fit. It was then I came across this post.
Attached are the right dimensions for the block mounting holes.
Hope it helps.
Old 01-17-2014, 10:36 AM
darren roar's Avatar
I found this a while back. Hope it helps. Worse case you could use a set of screw spotters or a piece of cardboard and a ball peen.
[IMG][/IMG]
Old 01-17-2014, 01:49 PM
Pop N Wood's Avatar
Using inches to dimension a metric motor doesn't exactly build credibility.
Old 01-22-2014, 06:13 PM
If anyone knows the thickness of the water pump spacers needed to use an f - body pump with with truck accessories that would be awesome
Old 01-23-2014, 08:05 AM
LXguy's Avatar
Haha, got your email!
For $59.99 shipped I can save you the trouble of making them (PM for discount).
http://www.scramspeed.com/LSx-billet...it-p/sc100.htm
Steve
Old 01-23-2014, 11:06 PM
LS1MCSS's Avatar
Hope it helps.
Yep, I learned that **** the hard way over a year ago, myself.
Old 01-23-2014, 11:10 PM
LS1MCSS's Avatar
If you're using an f-body pump for the straight out water connection, just switch to a LS3 gen5 camaro pump. It matches truck accessories and the outlet points forward.
Quick Reply: LS1 Motor mount plates, prints?
