331" De-Stroked LSx.. 8500 rpm??
Old 07-29-2011, 01:54 PM
11 Second Truck Club
sprayinLS1s's Avatar
Default 331" De-Stroked LSx.. 8500 rpm??
just like the title says, im thinking about building a semi cheap, super high reving motor. basic plan is to use a 6.0 iron block, 4.8 crank, LS3 heads, solid roller cam
considered going 2 directions, either 12.0:1 compression with nitrous
or about 9.0:1 comp with a pile of boost.
either way i know that i'll need some kind of aftermarket ignition setup, most likely a crank trigger, msd box, distributor, cause i know it will turn more rpm's than what the factory ecu can handle, im NOT going to buy a BS3 or anything of that sort.
so it will be carb'd and probably in the 8500 rpm range.
has anybody built something along these lines?
and what kind of issues have you had to make it work?
sprayinLS1s is offline
Old 07-29-2011, 02:36 PM
Darkman's Avatar
This idea in various forms come up from time to time. Most folks get talked out of it.
https://ls1tech.com/forums/generatio...go-forged.html
Darkman is offline
Old 07-29-2011, 02:56 PM
dkota1968's Avatar
Katech does something similar with a 427 block and small stroke in a crate engine
dkota1968 is offline
Old 07-29-2011, 03:10 PM
roswald0511's Avatar
What can the factory ECU read for maximum rpm's?
roswald0511 is offline
Old 07-29-2011, 03:21 PM
dug
dug's Avatar
thats because stock valvetrain is maxxed out at around 7500rpms.
the amount of air pumped with a 331@8500rpms is similar to a 408@6900rpms
dug is offline
Old 07-29-2011, 03:48 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Those two things don't go hand in hand....."super high" RPM's mean exotic lightweight parts and very expensive valve gear. Also, the risk of expensive catastrophic engine failure goes up exponentially so after you absorb the cost of building something like that the first time you need to be prepared to do it again in the event it grenades (or go a different route at that point).
The reason most people are talked out of it (and into simply building a more reliable larger motor that makes more average power) is because it just makes sense!
The way I see it there are two reasons to build a small CID screamer......your class limited to "X" cubic inch and have no choice.....or you like to be different and have a ton of money to invest in building something more unique and are willing to sacrifice reliability and low/midrange torque for the wail of an 8500+ RPM smallblock.
Just my opinion of course....
-Tony
PS.....Quick story.....back when I was still working at Shafiroffs place we dealt with a guy overseas that had more money than gray matter in my opinion (actually he just had alot of money!....LOL). In a class of cars running 540's to 632 CID bigblocks at the time (no displacement limit), he was bent on running a 440 CID BBC with huge Pro Stock style heads and he routinely turned it to 10,000 RPM.....even now thats a highly respectable RPM figure....more crazy back in the 90's when this took place. He was competitive and it made similar power to the big motors (at 2500 more RPM!), but this guy grenaded a $30,000 BBC at least four times in the thre years I was there to witness it. We pleaded with him to build a bigger engine for less RPM and more reliability and he said he just loved the sound of this motor at 10K and wouldn't trade it for the world. Good thing this guy had the pocketbook to back up what he wanted....hell Scott wasn't complaining either with all the expensive rebuilds!.....LOL (btw....when an engine comes apart at 10K the only parts used in the rebuild is the intake and carbs after you clean the aluminum chips from them!!)
Good luck....hope this PM gives you some food for thought!!
Cheers,
Tony
Tony Mamo @ AFR is offline
Old 07-29-2011, 04:00 PM
awd2rwd's Avatar
probably in the 8500 rpm range?
If you were going to do this why only rev to 8500?? Seems like a waste considering there are some 4.00" crank strokers that rev to 7800.
Anybody know what RobZ revs his 388ci motor to??
awd2rwd is offline
Old 07-29-2011, 04:31 PM
ZGLASS's Avatar
I think he takes it to like 8800rpms.
ZGLASS is offline
Old 07-29-2011, 05:52 PM
KCS
KCS's Avatar
SAM and HKE have turned 4" strokers up over 9600RPM.
KCS is offline
Old 07-29-2011, 06:14 PM
gnx7's Avatar
cheap/budget high revving builds..... love these topics. They don't exist
My vote is 6.0 iron block, stock crank, quality rods/pistons, doweled main caps and thick deck heads with medium sized hyd cam for boost.
Good driveability with crazy potential under boost.
I would love to hear about someone running the "Andreas" Swedish guy's head gaskets making 1000rwhp+. They are $400/set I believe.
gnx7 is offline
Old 07-29-2011, 06:34 PM
RezinTexas's Avatar
distributor on an LS1? has that ever been done? why?
RezinTexas is offline
Old 07-29-2011, 06:45 PM
kmracer's Avatar
RPM's = ruins peoples motors...
my question is WHY do you want to take cubic inches (and power) away from your combo? and FYI theres alot more to RPM than stroke, and you can build a 6.0 to rev to the moon just like you can build a 331 to rev to the moon. i'll take the same parts, and the same money. guess which one will make more power?
perhaps you should buy a honda?
kmracer is offline
Old 07-29-2011, 06:50 PM
farmington's Avatar
amen.
farmington is offline
Old 07-29-2011, 06:54 PM
kmracer's Avatar
its been done, but again, why? i thought people convert dist engines to COP? weird.
kmracer is offline
Old 07-29-2011, 07:19 PM
S10xGN's Avatar
Distributors are used on high RPM motors where the stock reluctor wheel doesn't have enough resolution to produce accurate spark.
S10xGN is offline
Old 07-29-2011, 07:28 PM
kmracer's Avatar
i was being a little sarcastic. obviously a BD dist is a great idea. i actually didnt read where he said " aftermarket ignition setup, most likely a crank trigger, msd box, distributor"
i was thinking he ment an msd cam driven GMPP setup, which is silly IMO.
kmracer is offline
Old 07-30-2011, 01:07 AM
For the smart ***'s:
The Z-28 in my sig pic is mine, it has a 365 iron block, running a 76mm turbo on a rear mount setup that I built from scratch, its a 9 sec car on pump gas with ice cold a/c and can be daily driven, so I know what that combo is capable of
I also had a +5000# truck that ran low 11s on a stock bottom LS1, both vehicles of which i did every bit of work on and tuned with efi live, so I'm not ignorant of the platform.
For those who made quality posts, you are greatly appreciated
The reason I was thinking about this is cause I may get a notch back stang or gen 3 f-body to build for a grudge car, so it's going to be light weight since it won't have creature comforts, basically a licensed race car, that's why I'm not too worried about average power. If it was a DD street car, i wouldnt have made this thread, cause Id put a 6.0 with a cam in it and been done. Besides it'll be nice to show what the same cubes in a LSx can do versus some of the 331/347 SBF stang boys. Takes away their crutch of crying about cubic inches, I hear alot of that **** at the track.
Also know a guy with a 6.0 LS in a notch back and I know how fast that car is for a budget build and only going to 6300 rpm.
Old 07-30-2011, 01:29 AM
True, but i don't have the backing to build a motor like theirs, or have my own machine shop/ dyno for doing R&D
The bottom end won't be too bad to build, but like Tony said, the valve train is going to be the hard/expensive part to get right.
With the smaller cubes I think the LS3 heads and a Vic Jr should keep up on air flow, so that will save alot of money.
I've seen a few different ignition setups on the all motor LSX cars, but I dont know the pros/cons of them.
Cause like some have said, it would be pointless to do a motor like this and not go well over 8000, I do agree with that.
Hell my 6.0 goes to 7200... lol
Old 07-30-2011, 01:30 AM
NightmareTA's Avatar
I think it's a cool concept. Nothing like the sound of an 8000+ rpm small block. I do agree with the other guys about not budget friendly though. That kind of rpm requires very lightweight parts in the rotating assembly and that stuff is by no means "budget." I'd be curious to see what kind of power it made with a monster cam.
Guy I know has a 349 CI fox body. Spins that thing to 8000 RPM's and there is nothing in the world that sounds like that. He raced another freind in a H/C/nitrous LS1 camaro to his stangs all motor setup and actually put a few cars on him FROM A ROLL. Very impressive to say the least.
NightmareTA is offline
Old 07-30-2011, 02:02 AM
A stock 4.8 crank with some weight reduction ought to work, they have plenty of over lap on the mains and rod journals, so it should be almost indestructible. With the shorter stroke, the balancing won't be as critical as it would on a 3.62/4.00 crank, since it's not going to have the same inertia, and the rod/piston speed won't be as high for the same given rpm as a bigger stroke. (I know balancing is still very important)
It's basically a modern day DZ302 like the 69 Z-28, and I've had the privilege of riding one of those cars and I know they could put a hurtin on the same car w/ a 427 BBC
Quick Reply: 331" De-Stroked LSx.. 8500 rpm??
