Didn't pass smog, high hydrocarbons..??
Old 07-14-2011, 11:39 AM
xxRONNIExx's Avatar
Default Didn't pass smog, high hydrocarbons..??
Well my 94 didn't pass smog this mourning. The visual and functional check passed but the emissions didn't.
I was told it was letting out high Hydro carbons. The max you can have at 15mph is 58, I was at 148 and at 25mph (max is 34) I was at 61.
What can cause high hydrocarbons?
I took out my Longtubes and put in some smog legal pacesetters and a new catalytic converter. Could that be one of the causes?
Old 07-14-2011, 01:26 PM
Village Troll
SS RRR's Avatar
It can be from a mess of things. Easiest question to ask is did they test the car when it was at operating temperature?
Here's a list of crap:
http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
Old 07-14-2011, 01:32 PM
djjab57's Avatar
No cat defiantly cause a problem
Old 07-14-2011, 01:41 PM
Village Troll
SS RRR's Avatar
What kind of catalytic converter is it?
Old 07-14-2011, 03:02 PM
arizona iroc's Avatar
They told me I needed a new egr valve when my Formula failed. It turned out I just needed to take the old egr out and blow out the carbon from the valve and the back of the intake manifold.
http://shbox.com/1/4th_gen_EGR.html
I aced the test after that. Hope it helps
Old 07-15-2011, 04:07 PM
xxRONNIExx's Avatar
Thanks for the help guys...I think this might get expensive just trying to figure out the problem. Can you also fail smog if you engine is running rough?
Old 07-15-2011, 05:51 PM
pillarpod's Avatar
if its not running proprerly, i would say yes, its sure isn't going to help
Quick Reply: Didn't pass smog, high hydrocarbons..??
