msd 2 step wiring
Old 07-12-2011, 09:35 AM
ToxicWS6's Avatar
Default msd 2 step wiring
lookin at the msd 2 step 8733, i want to run it off the clutch so id use the white/blue wire, but i also wanna run it off a switch, basically if the switch is on then when i hit my clutch in it will activate, but if the switch is off then its off even if i hit my clutch, would i run the white/blue wire through a switch then to my clutch pedal or would i use the other wire? thanks!
Old 07-12-2011, 10:10 AM
Fbodyjunkie06's Avatar
Do not use both wires. MSD instructions state do not use white/blue and blue wire at the same time.
You will need a switched relay or a clutch switch.
Quick Reply: msd 2 step wiring
