How Much Fluid Does the 4l60E Take?
Old 05-24-2011, 03:15 PM
bluebird71's Avatar
Default How Much Fluid Does the 4l60E Take?
I got a used 4L60 with the complete LS1 dropout I bought to put back in my T/A. It was drained (as much as possible) but still attached to the motor with the stall and everything in tact. How many quarts do I need to buy to fill it up?
Old 05-24-2011, 03:59 PM
346ci's Avatar
It could vary, but I would guess 5-8 qts. assuming just the pan was sucked out. I think total capacity is about 11qts.
Old 05-24-2011, 04:44 PM
Wildcobra's Avatar
six qts
Old 05-24-2011, 05:08 PM
LS1Tech Sponsor
performabuilt's Avatar
Depending on how long was drained etc could be anywhere from 5 to 12 quarts I would add five start then add till full.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-24-2011, 08:08 PM
senicalj4579's Avatar
When I did my ss3600 install I stood the trans up on its tail and got everything I could out. This was after I drained the pan of its fluid also. I ended up filling it with about 9-10 qts total.
Old 04-09-2012, 10:30 AM
bluebird71's Avatar
I added a tranny cooler and it feels a bit laggy on the shifts now. They say to add an extra qt. with a cooler, but is that ok to do even when the dipstick is showing full? Can you hurt the tranny by overfilling it?
Quick Reply: How Much Fluid Does the 4l60E Take?
