What's the largest cam i can run on an ls1 with stock heads?
Old 05-07-2011, 02:30 AM
SaskeyZ28's Avatar
Default What's the largest cam i can run on an ls1 with stock heads?
Looking for a good cam for a stock heads ls1 camaro. Was thinking about the TSP Torquer V2, but dont know if i can run on stock heads. Any advice or knowledge on the matter?
Old 05-07-2011, 02:57 AM
01ssreda4's Avatar
V2 will be fine for a stock headed LS1. What are your overall goals for the car?
Old 05-07-2011, 03:57 AM
wickedbluess's Avatar
i ran the tsp torquer v2 on stock ls6 heads with no problems, you should be fine.
Old 05-07-2011, 06:04 AM
Reaperchild's Avatar
Largest cam would be the opposite of what you want for a daily driver or a weekend car, not to mention gas prices !! Check out the SEARCH ^^ "EPS CAM" great product & review very positively, don't be affraid of going with larger duration cams as long as you match your Cylinder heads & intake combo + your trans box if your car is an auto A4 ! Good luck with your choice of cam but if tsp tv2 is in your head then look @ the MS3 reviews too !!
Old 05-07-2011, 06:54 AM
hfthe3rd's Avatar
I ordered the tsp torquer v3
Old 05-07-2011, 07:07 AM
garygnu's Avatar
you need a good flowing exhaust and tune.need gears and a stall converter.how many miles on the motor?
Old 05-07-2011, 02:33 PM
SaskeyZ28's Avatar
I've got about 135k miles on it :/ im planning on breaking the whole motor down in about a month to rebuild it and thought I might as well throw a cam in it, but with the amount of miles I don't know if I should put just a cam, or if I need heads also.
Old 02-13-2012, 06:48 PM
Matthadix's Avatar
Ive got a 98 ta I just bought, has a polluter cam like 605 intake and exhaust.is this to big for stock headsthat have been ported and polished?
Old 02-13-2012, 07:10 PM
moeZ28's Avatar
Trex v2...
Old 02-13-2012, 08:31 PM
Petersen's Avatar
I'm running a MS4 on stock heads
Old 02-13-2012, 08:51 PM
juSStin4171's Avatar
good question! I'm sure there's a lot of us out here that have still never done a cam swap, head swap etc. with our LS1's. Maybe someone can get quasi-technical about why "x" cam will work or why "xx" cam won't. I'm sure it's more than just the lift going past .6?? and the duration being more than what a stock head can flow.
*subscribed*
Old 02-13-2012, 09:07 PM
Zmg00camaross's Avatar
Its all on the goals of your car and your application. My car is on the lighter side, 4.56 gears and the supporting mods for a larger camshaft. so I am running eps 234/246 on a 111lsa. And should run good for my goals. But if your full weight and are not going to be drag racing and all that. a smaller cam will benefit better then a larger top end peaky cam. So OP what are your goals?
Old 02-14-2012, 10:24 AM
autogeek23's Avatar
i think stock heads dont flow good over .600 lift and either does an ls6 intake. but im not 100% on that. i thought i read it somewhere on here in a sticky, read through stickys
im at work and the filter wont let me view some sections of tech. i think i read about stock heads flow at over .600 lift in a thread about achieving 500 whp n/a.
Old 02-14-2012, 07:27 PM
COPO9560's Avatar
You will not get 500 rwhp with stock heads.
Old 02-14-2012, 11:05 PM
01ssreda4's Avatar
If everything else in the combo is done really well, and you have heads that were touched by the right person/machine, I'd say you can get damn close.
Here's 500 on a 6.0, a 5.7 would be close behind
https://ls1tech.com/forums/dynamomet...st-2009-a.html
Old 02-14-2012, 11:08 PM
White Shadow's Avatar
Stock heads means untouched/unported/unmilled.
Old 02-14-2012, 11:27 PM
01ssreda4's Avatar
Well if that's what he meant then i whole-heartily agree
Old 02-15-2012, 11:28 AM
KC Henry's Avatar
I agree, do a search for "EPS" cams. Then Call (not email) Geoff at EPS (site sponsor).
Quick Reply: What's the largest cam i can run on an ls1 with stock heads?
