need help finding a tool to hold the crank in place..
Old 04-29-2011, 05:41 PM
1sicws6's Avatar
Default need help finding a tool to hold the crank in place..
The Ls shop I use to work at had a tool that bolted up in place of the started on a ls motor which worked great for torqueing down pulleys but I cant find it does anyone have a clue who sold it? thanks
Old 04-29-2011, 09:20 PM
BADD SS's Avatar
Kent-moore flywheel lock tool. Dont know the part # though.
Old 05-05-2011, 07:31 PM
camarof41_383's Avatar
http://www.etoolcart.com/flywheelhol...j-42386-a.aspx
I want one of these but keep hoping someone will make a tool to do the same thing for cheaper.
Old 05-12-2011, 05:47 PM
Pocket's Avatar
Simple
Take an old flexplate and cut a small section off it, then weld it to a piece of scrap steel and drill two holes in it
Old 05-13-2011, 09:00 PM
Mike52's Avatar
Originally Posted by Pocket
Simple
Pocket, I like the way you think!!
Old 05-14-2011, 07:24 AM
LS1MCSS's Avatar
Just make two small brackets to bolt this on where the starter goes.
http://cgi.ebay.com/ebaymotors/UNIVE...item20b60555a4
Old 05-15-2011, 06:31 PM
Pocket's Avatar
$50-100 vs free using old scrap
Answer is simple in my book
Old 05-16-2011, 10:01 PM
Gray86hatch's Avatar
screw a bolt in the block bellhousing hole or use the bellhousing
Tim
Old 05-19-2011, 12:22 AM
01ssreda4's Avatar
Kent Moore tool is better..........
Quick Reply: need help finding a tool to hold the crank in place..
