Car won't start making a grinding noise!
Old 04-06-2011, 12:09 PM
ChevyEnthusiast's Avatar
Default Car won't start making a grinding noise!
All of a sudden my car started making a grinding noise this morning but it started. I leave school to head to work and the grinding was worse when starting but it still started well i got to work and and turned the car off then out of curiosity i tried to turn it over and grinded but no start tried it a couple times. Im hoping its the starter even though ive never encountered a starter going out this way. Need some expertise on this, is there any way to get my car to start to get it home.
Old 04-06-2011, 12:16 PM
jason2687's Avatar
It's definately your starter man. If your car is stick you can push start it... Have someone push the car while in neutral and then pop the clutch....
Old 04-06-2011, 12:30 PM
Deceptikon's Avatar
Be sure to check the flywheel the starter connects to. Depending on how long you've been grinding the teeth on that starter you may have broken teeth on the flywheel.
Old 04-06-2011, 08:38 PM
dstappity's Avatar
Check your main ground wire for a good connection to the frame, if its barely grounded it can make a "grinding" noise while trying to start, mine does it.
Old 04-10-2011, 12:45 PM
It was the starter i ended up having to get it towed cost me 80 bucks my car is automatic so a jump start was out the question I put a new rebuilt one on, my old starter was busted all to hell. Im just glad i didnt screw up the flywheel, but thank the good lord shes back and running.
Old 04-10-2011, 04:10 PM
Ghostintheshell's Avatar
starter +1000
Quick Reply: Car won't start making a grinding noise!
