Ran out of gas- now wont start
Old 03-28-2011, 06:00 PM
zaaronz's Avatar
Default Ran out of gas- now wont start
Like the title says- i was on the way home and was gonna get gas- but my wife called me and i just forgot. The car started to feel like it was about to run out of gas so i let off the gas and rolled down hill into a gas station. Just before i pulled in it ran out and died as i coasted up to the pump. I put 30 bucks of gas in but it did nothing. It just turns over like its getting no fuel at all. Nothing looks out of place and i checked the fuel pump fuse and its good. Any ideas of what it could be?? Any help is much appreciated.
Old 03-28-2011, 06:04 PM
Joshu's Avatar
You might have fried your fuel pump which can be very costly. The fuel helps cool the pump (radiates the heat I beleive.) Others with more experience than I might be able to offer more assistance.
Old 03-28-2011, 06:07 PM
lt56026's Avatar
Turn the key on and off 5 times without turning the motor over to get enough presure in the fuel rail then try and start
Old 03-28-2011, 06:08 PM
lt56026's Avatar
Let me know if it works
Old 03-28-2011, 06:16 PM
99FormulaM6's Avatar
First thing is to check and see if you can even hear the fuel pump prime when you turn the key to the 'on' position. If not, then its fried.
Old 03-28-2011, 06:23 PM
zaaronz's Avatar
yeah i tried that a bunch of times before i had it towed home- didnt help. The gas station had stupid music playin so loud i couldnt listen for the fuel pump- and now the batts dead from trying to crank it so much. Guess the next step is to charge it and see if i can hear the fuel pump when i turn the key.
Old 03-28-2011, 06:34 PM
CJDZ24_Z28's Avatar
how many miles on the car and what year is it? I'm pretty sure your pump is dead. This happened to me in my old 98 Trans ams with 135k. Ran out of gas and that was the end of the pump. If you do a fuel pump cutting a access hole is the easiest and fastest way. It will take you less than a hour
Old 03-28-2011, 06:38 PM
SOMbitch's Avatar
The pump is toast. Run it dry and it is done. Sux but true...
Old 03-28-2011, 06:42 PM
dlross's Avatar
yea sounds like the put is fried or if the pump comes on its possible that you suck up dirt from the bottom of the tank a stuck in the screen. happened to me once.
Old 03-28-2011, 06:44 PM
zaaronz's Avatar
Yep i guess i burned it up- I dont hear it prime at all when i turn the key now. im gonna blame my wife for calling me and making me forget to get gas... This pump looks like a good price at the ws6store http://www.ws6project.com/user_stor/...oducts_id=2923 Is that a good pump. How hard is it to replace? Anyone know of a link on here of a step by step?
Old 03-28-2011, 06:54 PM
easiest way is to cut a trap door above the tank, but dropping the tank completely is the correct (and harder) way to do it. Search in the fueling section and there are write ups.
Old 03-28-2011, 07:21 PM
zaaronz's Avatar
thanks ill have to look into this trap door way...
Old 03-28-2011, 07:38 PM
ULTIMATEORANGESS's Avatar
since its your wifes fault have her fix it.
Old 03-28-2011, 07:40 PM
Xtreme864's Avatar
I recommend installing a fuel pump door if you're gonna cut an access hole. if you try to reseal it with tape or glue of some kind, you will have fumes enter your interior from both the fuel tank and the exhaust.
Another useful trick in the future to see if your pump is fried if you can't hear it is to check the Schroeder valve. There is one on the driver side of the fuel rail. If you push it in and no fuel comes out or it just dabbles out, your pump is bad OR your fuel filter could be clogged. I recommend replacing them both at the same time.
Old 03-28-2011, 08:03 PM
LS6427's Avatar
Check your fuse first man. I've run out of gas in my car like 8 times in the past 10 years, the pumps do not fry if you run out of gas......lol....when will this ridiculous myth go away.
Not saying the fuel pump didn't fail...just check the fuse first.
Old 03-28-2011, 08:09 PM
zaaronz's Avatar
Well she didnt like that idea--- so.. i guess i have to blame it on yall guys. Why didnt yall tell me not to run my car outta gas?
blair (04-05-2024)
Old 03-28-2011, 08:12 PM
zaaronz's Avatar
Yeah i checked it- that was one of the first things i did. I even switched it with another of the same volt just to make sure. I sure wish it would have been a fuse.
Old 03-28-2011, 08:19 PM
LS6427's Avatar
There's no issue with running out of gas........it causes nothing to happen to the pump. If it did mine would have been toast after 8 times of doing it.
How long did it run while out of gas? It can run for awhile.
If the fuses are good, maybe disconnect the battery and reconnect it. Don't know what that'll do, but try everything before cutting that flap door to replace it. Its not a fun job from what I've been told.
Old 03-29-2011, 03:08 PM
Joshu's Avatar
Then I would assume you are a lucky fella. It might be coincidence the pump on my van died the same instant I ran out of gas.
Old 04-01-2011, 07:00 PM
Brando5641's Avatar
yea josh crap didnt you know that fuel pumps last forever? Gezzzz also you might check the coolant that goes to the fuel pump it might be out...
Fuel pump going out........lol that never happens.... lol
Hey ls6 he prob. has the silent FP mod lol lol
Aron i would check the relay and if its good slap a fuel pump in it. Do the trap door. Aftermarket pumps dont last long. Also dont let your car get below 1/4 of a tank. The pump uses the fuel as a coolant. On high milage cars this is a killer to run it out of gas.
Quick Reply: Ran out of gas- now wont start
