6.0 to 5.3 swap
Old 03-24-2011, 02:15 PM
jvinso2's Avatar
Default 6.0 to 5.3 swap
i have a 2004 5.3 from a 1500, my 2002 2500 hd 2wd has a 6.0, i am going to swap to the 5.3, will i need anything for the flywheel, or some type of spacer, the trans is a 4l80. and also i know the 5.3 has less torque and hp, but the truck has 4.10 gears and will the fuel mileage increase
Old 03-24-2011, 02:33 PM
LT/LS Guy's Avatar
What? Did the 6.0 take a crap or something?
Old 03-27-2011, 10:20 AM
GoatPilot87's Avatar
I doubt fuel mileage will increase chief. Are you basing that just off of engine displacement? The 5.3 will have to spin higher to make the same power as that 6.0L, thus MORE fuel used because it will have to work harder to get the same job done. Id rebuild the 6.0L and be done. You'll have more "useable torque" where you need it for a truck with a larger displacement engine.
Old 03-27-2011, 10:21 AM
Mean87SS's Avatar
The 5.3 trucks don't get alot better if any vs the 6.0...
Old 03-27-2011, 04:39 PM
30th t/a's Avatar
I have 2 buddys that have the 5.3 and regret it and tell me all the time how they wish they went with the 6.0.
Old 03-27-2011, 05:34 PM
98Z28MASS's Avatar
I had the 5.3 in my Suburban and now I have the 6.0 in my Escalde EXT and I will take the 6.0 100 out of 100 times. I actually get better gas mileage with the 6.0 over the 5.3
Quick Reply: 6.0 to 5.3 swap
