want/need to disable factory alarm.
Old 03-20-2011, 10:27 PM
98 4X4 burban's Avatar
Default want/need to disable factory alarm.
i am using an entire harness from a 2000 in my 95 camaro. i have the vats deleted and the bcm bypassed for the fuel enable. the car starts and runs fine. well today i tied up some loose ends on the car and when i locked and shut the door the alarm armed itself and started going off. is there a way to delete/disable the factory alarm?
Old 03-20-2011, 10:44 PM
Crispy's Avatar
That info can be found in your owners manual, if you dont have it, check this link:
https://ls1tech.com/forums/2965615-post5.html
Old 03-20-2011, 10:48 PM
i do not have a keyfob. i have already looked at that thread and it did not help. i just want to remove or disable it all together.
Old 03-21-2011, 12:36 AM
Save the manuals!
wssix99's Avatar
Put the key in the ignition cylinder and turn at least one click.
Crispy's link will tell you how to keep the alarm from arming.
Old 03-21-2011, 07:14 AM
Ungrounded Moderator
WhiteBird00's Avatar
You don't need a remote to disable the alarm. If the method posted doesn't work then you're pretty much out of luck because the alarm is in the BCM and it can only be disabled by programming (there is no switch or separate wire).
Quick Reply: want/need to disable factory alarm.
