Sponsored by: DashLynx
Old 05-20-2016, 01:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
Official 4th Gen F-Body Light Bulb List
Old 03-17-2011, 01:32 AM
ZexGX's Avatar
See below, and post up if you see anything that needs to be corrected/added. It's official, since I got the list from a GM dealers computer system and verified each listing, and NOT the incorrect Sylvania list that everybody copy/pastes without checking.
NOTE: No-Load flasher modules are recommended for LED conversions when doing turn signals/running lights/brake lights/tail lights to avoid having to hack up the wiring harness by adding resistors or paying for more expensive LEDs with resistors built in. There are many LED-compatible flasher relays on the market which change in availability year-to-year so do your homework. Flasher modules/relays control the timing of the turn signals and hazard lights - OEM-supplied ones are shaped like round metal canisters. 93-02 Camaros and Firebirds have two - one for turn signals, one for hazards.
US Model Exterior:
Fog Light (93-97 Camaro): 885
Fog Light (Camaro): 894X
Fog Light (Firebird): 880
Headlight Low (93-97 Camaro): H4351
Headlight High (93-97 Camaro): H4352
Headlight Lo/Hi (93-97 Firebird): H4666
Headlight Low (98-02 Camaro): 9006
Headlight High (98-02 Camaro): 9005
Headlight Low (98-02 Firebird): H4703
Headlight High (98-02 Firebird): H4701
Front Turn Signal (Camaro): 3157 (Clear Glass)
Front Turn Signal (Firebird): 3157NA (Amber Glass)
Front Side Marker: 194
Rear Side Marker: 194
License Plate Light: 194
Reverse Light (93-96 Camaro): 1156 or 1157
Reverse Light (93-97 Firebird): 1156 or 1157
Reverse Light (97-02 Camaro): 3155 or 3057 or 3157
Reverse Light (98-02 Firebird): 3155 or 3057 or 3157
Third Brake Light: 921
Brake/Turn Light (93-97): 2057
Brake/Turn Light (98-02): 3057
Outer Brake Light: 194
Export Model Exterior:
Fog Light: H3
Park/Signal Light (front): P27/7WLL
Fender-mounted Turn Signal: W5W
Third Brake Light (Camaro): W16W
License Plate Light: W3W
Rear Fog Light: P21W
Brake/Rear Turn Signals: P21/W5
Outer Brake Light: W5W
All Interior:
Ashtray Light: 161/194
Automatic Shifter Light: 73
Door Handle Bezel Lights: 74
Headlight Switch: CNW1-7219 (LEDs = PC118 or 3mm neo-wedge)
HVAC Lights: 37 (LEDs = T5 Wedge)
Gauge Cluster Backlight: 161
Gauge Cluster Icons (Camaro): 161
Gauge Cluster Icons (Firebird): PC74/161
Glove box light: 194/161
93-98 Map Lights(?): 214-2 (LEDs = 42mm festoon)
99-00 Map Lights: 212-2 (LEDs = 44mm rigid loop festoon)
01-02 Map Lights: 194 (LEDs = 194/906/921)
Rear Dome Light: 212-2 (LEDs = 44mm rigid loop festoon OR a 20-SMD LED panel plugged into the stock harness connector)
Bump. Any changes/suggestions? Is this accurate for 93-97 cars?
The following 6 users liked this post by ZexGX:
btnautical007 (04-06-2023), camaro322hp (11-17-2020), fucter (01-25-2021), HalifaxTA (02-26-2022), metalmechanic (07-22-2019), ReFtheMC (10-10-2023) and 1 others liked this post. (Show less...)
Old 03-24-2011, 07:07 AM
fbodyrs96's Avatar
93-97 camaro fog light 885
Old 03-24-2011, 07:12 AM
MTBSully's Avatar
damn good post. Sticky?
Old 03-24-2011, 11:37 AM
ZexGX's Avatar
Thanks! List updated. Will be verifying/clarifying Gauge Cluster bulb information today.
Old 03-24-2011, 04:10 PM
Brangeta's Avatar
This is pretty useful. All I have is GM part numbers that are a pain to figure out for the bulbs.
Old 05-24-2011, 07:30 PM
ZexGX's Avatar
Bump.
Old 05-24-2011, 08:29 PM
HoLLo's Avatar
01/02 mirror map lights are 194 bulbs. I just put some in.
Old 05-24-2011, 10:35 PM
ZexGX's Avatar
194 bulbs are the same socket as what is listed. 194s are actually underwattage bulbs for map lights on 01-02.
Old 05-31-2011, 12:12 AM
lemons12's Avatar
Nice.. sticky it!!
Old 05-31-2011, 11:07 AM
LeanPocket's Avatar
thank you, bookmarked
Old 05-31-2011, 02:46 PM
AZ2ENVY's Avatar
1993 and early 1994 Model year Camaros front turn signal bulbs : 2397
1993-1996 Camaro cluster bulbs : 161 bulb with housing soldered together
1993-1996 Camaro Rear turn signal : 2057
1993-1996 Camaro Brake Light : 2057
1993-1996 Camaro Reverse light : 1141
Old 07-13-2011, 09:28 PM
BCKNBLK's Avatar
anyone know if the 98 TA mirror lights are the same???
Old 07-15-2011, 01:46 PM
ZexGX's Avatar
As listed, '93-'00 are 212-2 festoon bulbs. That means your car would need a 212-2 since it falls between '93 and '00. It's also not a 194 for the '01-'02 cars - it's a 906/921 bulb (higher wattage).
Old 07-15-2011, 06:23 PM
The Dragon's Avatar
Nice. Thanks!
I wanna replace a few interior lights with LED's
Old 07-15-2011, 06:33 PM
ZexGX's Avatar
Originally Posted by The Dragon
Nice. Thanks!
Just be careful with the map lights if you own a 93-00... They're a bitch. Either way, you should FIRST remove the mirror from the windshield by unplugging the electrical connector, and unclipping it from the windshield mount. Makes install much easier.
Old 07-20-2011, 08:31 PM
BCKNBLK's Avatar
why so,, wouldnt needle nose plyers reach em?
Old 07-20-2011, 10:11 PM
ZexGX's Avatar
If you want to crush the bulbs, sure.
Old 07-21-2011, 10:59 AM
hlaalu's Avatar
Are the 894X and 880 bulbs the same size? I bought the 880 HIDs for my camaro and they fit perfectly.
Old 07-21-2011, 11:06 AM
ZexGX's Avatar
They are. I want to say that the difference between 894x and 880 is that one of them is a right-angle plug, whereas the other is straight.
880: http://white-light.net/images/Xenon_...500K_27W_2.jpg
894X: http://www.hiperf.com/acatalog/181894.jpg
Old 07-21-2011, 11:34 AM
hlaalu's Avatar
Odd, mine were both right angle plugs. Does length have anything to do with it? The bulbs on the HIDs were much longer.
Quick Reply: Official 4th Gen F-Body Light Bulb List
