2000 C5 PCM Diagram
Old 02-16-2004, 12:02 AM
mikey94_95's Avatar
Exclamation 2000 C5 PCM Diagram
Hello guys, I'm new to the forum, and would like to ask a few questions to kick things off.
1.
I'm looking for a PCM Pinout Diagram for a 2000 Corvette with manual transmission.
I've used the SEARCH function and have found some results but all the links posted were invalid.
If you could post the diagram(s) here or send it to me at zzquad@netnitco.net I would be VERY greatful.
2.
In a related question, I am looking for a tach signal at the PCM on this same car.
I believe that this is pin #10 (not pin #35) which is in 4-cylinder mode.
Can anyone verify this for me?
Once again, thank you!
Old 02-16-2004, 12:32 AM
mikey94_95's Avatar
Arrow ttt
ttt
ttt
ttt
Old 02-16-2004, 10:26 AM
mikey94_95's Avatar
Thomas, thanks for the email. Its a great start...
Can anyone post a diagram?
Thank you once again!
Old 02-16-2004, 12:33 PM
98blackSS's Avatar
No problem. I have a scanner at work, unforunately I won't be back there until Thurs. If you can wait that long, I could scan it then.
Old 02-16-2004, 02:50 PM
etperformance's Avatar
Document ID# 553912
2000 Chevrolet/Geo Corvette
Powertrain Control Module (PCM) Connector End Views
Table 1: PCM Connector C1 (BLU)
Table 2: PCM Connector C2 (RED)
Connector Part Information
PCM Connector C1 Assembly 12191489
TPA (BLU) 12176408
Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
LT GRN
1867
Crankshaft Position Sensor B+ Supply
3
PNK/BLK
1746
Injector 3 Control
4
LT GRN/BLK
1745
Injector 2 Control
5-6
Not Used
7
GRY
596
Engine Oil Pressure Sensor 5V Reference
8-10
Not Used
11
LT BLU
1876
Knock Sensor Signal Rear (KS2)
12
DK BLU/WHT
1869
Crankshaft Position Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
TAN
800
Throttle Actuator Control Serial Data
15
ORN/BLK
1061
16
Not Used
17
DK BLU
1225
Transmission Range Signal B
(Automatic Transmission Only)
18
RED
1226
Transmission Range Signal C
19
PNK
239
PCM Ignition Supply
20
ORN
340
PCM Battery Supply
21
YEL/BLK
1868
Crankshaft Position Sensor Ground
22
Not Used
23
GRY
720
Sensor Ground
24
Not Used
25
TAN
1671
HO2S Signal Low Bank 2 Sensor 2
26
TAN
1667
HO2S Signal Low Bank 2 Sensor 1
27
Not Used
28
TAN/WHT
1669
HO2S Signal Low Bank 1 Sensor 2
29
TAN/WHT
1653
HO2S Signal Low Bank 1 Sensor 1
30-31
Not Used
32
BLK/WHT
771
PRND A Input Signal
33
PPL
420
TCC Brake Switch
34
WHT
776
PRND P Input Signal
35
GRY
48
Clutch Switch
(Manual Transmission Only)
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Powertrain Induced Chassis Pitch Signal (if so equipped)
39
Not Used
40
BLK/WHT
451
PCM Ground
41
Not Used
42
DK GRN
335
Engine Cooling Fan Relay 1 Control
43
RED/BLK
877
Injector 7 Control
44
LT BLU/BLK
844
Injector 4 Control
45
GRY
474
A/C Refrigerant Pressure Sensor 5V Reference
46
GRY
598
Fuel Tank Pressure Sensor 5V Reference
47
Not Used
48
GRY
416
MAP Sensor 5V Reference
49-50
Not Used
51
DK BLU
496
Knock Sensor Signal Front (KS1)
52
Not Used
53
ORN/BLK
1057
Transmission Temperature Sensor Ground
54
ORN/BLK
469
MAP Sensor Ground
55-56
Not Used
57
ORN
340
PCM Battery Supply
58
DK GRN
1049
Serial Data
59
Not Used
60
BLK
407
A/C Refrigerant Pressure Sensor Ground
61
PNK/BLK
632
Camshaft Position Sensor Ground
62
GRY
847
Extended Travel Brake Switch Signal
63
BLK
452
Engine Oil Pressure Sensor Ground
64
Not Used
65
PPL
1670
HO2S Signal High Bank 2 Sensor 2
66
PPL
1666
HO2S Signal High Bank 2 Sensor 1
67
Not Used
68
PPL/WHT
1668
HO2S Signal High Bank 1 Sensor 2
69
PPL/WHT
1665
HO2S Signal High Bank 1 Sensor 1
70
BRN
1174
Low Oil Level Switch
71
Not Used
72
YEL
772
PRND B Input Signal
73
BRN/WHT
633
Camshaft Position (CMP) Sensor Signal
74
YEL
410
Engine Coolant Temperature (ECT) Sensor Signal
75
Not Used
76
BLK/WHT
845
Injector 5 Control
77
DK BLU/WHT
878
Injector 8 Control
78
Not Used
79
GRY or WHT
587 or 687
2nd and 3rd Gear Block Out Solenoid Control (M/T) or 3-2 Shift Solenoid Control (A/T)
80
BRN
718
Engine Coolant Temperature (ECT) Sensor Ground
PCM Connector C2 Assembly 12191488
TPA (RED) 12176410
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
BRN
418
TCC Control Solenoid
3
Not Used
4
PPL
421
AIR Solenoid Control
5
TAN/BLK
464
Torque Delivered
6
RED/BLK
1228
Transmission Fluid Pressure Control Solenoid High
7
Not Used
8
LT BLU/WHT
1229
Transmission Fluid Pressure Control Solenoid Low
9
DK GRN/WHT
465
Fuel Pump Relay Control
10
WHT
121
Engine Speed (Tach) Output Signal
11-13
Not Used
14
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
15
RED
225
Alternator L Terminal
16
Not Used
17
DK GRN/WHT
762
A/C Request Signal (C60 only)
18
DK GRN
59
A/C Status Signal
19
Not Used
20
PPL
401
Vehicle Speed Sensor (VSS) Reference Low
21
YEL
400
Vehicle Speed Sensor (VSS) Signal
22-24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
Ignition Control 1
27
RED
2127
Ignition Control 7
28
LT BLU/WHT
2126
Ignition Control 6
29
DK GRN/WHT
2124
Ignition Control 4
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK BLU
473
Engine Cooling Fan Relay 2 and 3 Control
34
DK GRN/WHT
428
EVAP Canister Purge Valve Control
35
Not Used
36
BRN
436
AIR Pump Relay Control
37-38
Not Used
39
RED
631
Camshaft Position Sensor B+ Supply
40
BLK/WHT
451
PCM Ground
41
Not Used
42
TAN/BLK
422
TCC Enable Circuit
43
DK GRN/WHT
459
A/C Clutch Relay Control
44
LT GRN
1652
Reverse Inhibit Solenoid Control
45
WHT
1310
EVAP Canister Vent Valve Control
46
BRN/WHT
419
Malfunction Indicator Lamp (MIL) Control
47
WHT or YEL/BLK
375 or 1223
1 to 4 Up-shift Lamp Control or Transmission Shift Solenoid B
48
LT GRN
1222
Transmission Shift Solenoid A
49
Not Used
50
DK GRN/WHT
817
Vehicle Speed Output Circuit
51
YEL/BLK
1227
Transmission Temperature Sensor Signal
52
GRY
23
Alternator F Terminal
53
Not Used
54
DK BLU
1936
Fuel Level Sensor Signal
55-56
Not Used
57
PPL
719
IAT Sensor Ground
58
TAN/WHT
331
Engine Oil Pressure Sensor Signal
59
Not Used
60
BRN
2129
Ignition Control Reference Low Bank 1
61
BRN/WHT
2130
Ignition Control Reference Low Bank 2
62
GRY
773
PRND C Input Signal
63
PNK
1224
Transmission Range Signal A
64
DK GRN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PPL/WHT
2128
Ignition Control 8
67
RED/WHT
2122
Ignition Control 2
68
DK GRN
2125
Ignition Control 5
69
LT BLU
2123
Ignition Control 3
70-72
Not Used
73
LT BLU
1937
Fuel Level Sensor Signal (Secondary)
74-80
Not Used
Document ID# 553912
Old 02-16-2004, 02:52 PM
Yes # 10, on connector 2
Old 02-16-2004, 10:36 PM
mikey94_95's Avatar
Thomas, yes I can wait! I'd like to have the visual reference to go along with the written diagram that etperformance has provided
(Thank you both by the way!!!)
Old 02-17-2004, 10:36 PM
mikey94_95's Avatar
ttt
ttt
ttt
Old 02-18-2004, 08:18 AM
Scooter70's Avatar
There's something going on at LS1.com where the diagrams used to be. They keep moving them around. I'm trying to find them for my own use. I'll let you know if I find it.
Old 02-18-2004, 10:37 AM
mikey94_95's Avatar
Lightbulb
Thanks!
That's were I was looking as well, but its all crunked up.
Thomas was going to scan it for me; just waiting for that.
Old 02-21-2004, 01:14 PM
mikey94_95's Avatar
Lightbulb ttt
ttt
ttt
Quick Reply: 2000 C5 PCM Diagram
