how to keep a/c?
Old 03-02-2011, 08:19 PM
FL Junkie's Avatar
Default how to keep a/c?
how can you build a turbo setup and keep your a/c? i am planning a truck manifold setup, but i may change the passenger side. i want to keep my a/c.
Old 03-02-2011, 08:28 PM
tpunk's Avatar
I beleive the recommendation has been to use a C6 manifold. I have heard people say one of the FWD LS4 manifolds can be used as well.
Old 03-02-2011, 08:32 PM
FL Junkie's Avatar
thanks. so do you flip the C6 manifold upward? how do you go around the compressor?
Old 03-02-2011, 08:46 PM
tpunk's Avatar
Honestly I'm not sure. I think the idea was that they exit more in the center aimed downward so you could fanangle it to get by the compressor somehow.
Old 03-02-2011, 09:06 PM
1badWS6's Avatar
I'm doing a truck/c6 manifold build and I'm planning on keeping the AC as well. From my assumption you have to use a drivers side manifold flipped and aimed downward. You can then route the tubing around the compressor/dryer housing as well.
Old 03-02-2011, 10:28 PM
FL Junkie's Avatar
can you get it by without a tubular kmember?
Old 03-02-2011, 10:40 PM
Adam86's Avatar
If your looking to build, I'm not sure. If you're looking to buy, talk to KYTP. Awesome guys with awesome parts. Hell, he might even help you if you don't buy from them.
Old 03-02-2011, 10:48 PM
evo462's Avatar
Depending on the size of your downpipe, you may be able to get enough space with solid motor mounts....might need to bend power steering lines out of the way though.
I decided to make it easy on myself and bought a BMR turbo k member.
Old 03-02-2011, 10:55 PM
evo462's Avatar
This thread might be helpful to you about c6 manifold plumbing.
https://ls1tech.com/forums/forced-in...bo-setups.html
Old 03-02-2011, 10:59 PM
evo462's Avatar
And another
https://ls1tech.com/forums/forced-in...dy-thread.html
Old 03-03-2011, 11:31 AM
FL Junkie's Avatar
i just did some measurements and it looks like its gonna be a tough fit with the stock kmember.
Old 03-03-2011, 11:34 AM
FL Junkie's Avatar
what motor mounts were you talking about?
Old 03-03-2011, 01:12 PM
evo462's Avatar
Solid motor mounts? Of various manufacturers?
Quick Reply: how to keep a/c?
