Fox Mustang Budget Swap/ Motor Mount Questions
Old 02-26-2011, 07:09 AM
SpeedDensityZ's Avatar
Default Fox Mustang Budget Swap/ Motor Mount Questions
Okay, I have done about 2hrs worth of searching and the most common way to put a ls series motor in a fox body is to use the 4.6 k-member and mounts. What kind of ground clearance does this give you if you're using a stock truck pan? I have seen the thread where tirefryin_s10 has picutres of oil pan clearance using the stock 4cyl kmember with custom made motor mounts but I haven't seen a thread on how to make mounts and what all is involved to use the 4cyl kmember. I know he used the truck top have and 4cyl bottom half. If anyone has some pictures and detailed info to share I would really apprecite it. I know there is fab work with both kmembers but I believe what I'm looking for is the most plug and play with he best clearance for the oil pan and headers. Anyway, here is a picture of the 5.3 I have going in and the car itself. I hope to make it a daily driver with A/C and all, deep dishes in the back, blah, blah, blah. I just got the car this week. I've already done the motor and started on the interior(BTW the block is painted ford blue, I thought it would be a little comical at car shows and such). When I get it finished then I'm gonna start paint and body then on to dropping the engine in and getting all the suspesion from fron the rear sorted out. When I get close to completion I will start a build thread.
Size:  38.8 KBName:  IMG_1245.jpg
Size:  35.5 KBName:  IMG_1242.jpg
Size:  36.2 KBName:  IMG_1279.jpg
Size:  39.4 KBName:  IMG_1287.jpg
Size:  43.0 KBName:  IMG_1315.jpg
Old 02-26-2011, 07:47 AM
boostnut's Avatar
love the ford blue!
Most common way (& probably the easiest) is to use the AJE kmember with lsx mounts & an f-body oil pan. I'm not sure anybody is running an untouched truck pan, probably a major ground clearance issue.
Old 02-26-2011, 01:49 PM
Yeah I thought the ford blue was pretty cool too. I figured that the AJE setup is the easiest route to go but I'm looking to save some Benjamins. Can anyone who has done the swap both ways chime in?
-Thanks
Old 02-26-2011, 05:39 PM
protracracing's Avatar
If you have to buy a K-member I don't see you saving much money by buying a 4.6 k-member and then having having to make motor mounts for it.
Dennis
Old 02-26-2011, 05:52 PM
gearhead302's Avatar
you can buy that aje for about 250. probly still need an oil pan though. the truck pan is uber low
Old 02-26-2011, 06:05 PM
serpentnoir's Avatar
Dennis
That's the whole point. You don't have to make mounts. Use the 4.6L mounts.
Old 02-26-2011, 09:40 PM
Well, I already have a 4.6 Kmember and A-arms. All I need is 4.6 mounts. I seen the thread where it shows you how to mod the mount to fit the iron block. Could I just use a 1/4 or 3/8" plate of steel and bolt the mounts to it and then to the engine? Has anyone done this instead of modding the mounts?
Old 02-27-2011, 03:40 AM
slow00gt's Avatar
I just modded my mounts. Super easy to do if you can cut and weld. My 5.3 is dark ford blue to that I just put in my 2000 GT. Get comments its on it all the time.
Old 02-27-2011, 06:28 AM
I personally cant cut and weld but luckily i have a buddy that owns a fabrication shop. Has anyone ever modified the truck pan for ground clearance? I think I'm gonna go with the stock 4.6 stuff and modify the mounts, clearance the oil pan if need be, and make my own headers if shorty header wont fit. Anyone with experience using ls1 or truck shorty headers?
Old 02-27-2011, 08:37 AM
boostnut's Avatar
Here's your headers.
http://www.brphotrods.com/mm5/mercha...ory_Code=CNV19
Old 03-06-2011, 02:37 AM
kmracer's Avatar
you can modify the pan for clearance, and just fabricate mounts, which is what i did for both the engine and trans. it wasnt too hard.
Old 03-06-2011, 06:53 AM
zipster's Avatar
On a Fox Mustang the 4cyl and v8 k member are the same. Also, I have a cut down truck pan removed 1 1/2 inches, I ended up buying a F body pan. Let me know if you want the truck pan.
Old 03-06-2011, 04:32 PM
modstang60's Avatar
Good luck on the build, looks to be going smoothly already
Old 03-06-2011, 09:20 PM
1961ba427's Avatar
Looks good, but Does this mean I won't be seeing any updates to your silver LT1 camaro thread?
Old 03-11-2011, 03:29 AM
Yeah, I just bought some 4.6 mounts to modify. It doesn't look like it's going to be too hard.
Cool, PM sent.
Not too bad, I just hate doing body work. I'm going to get the car to be a full nice roller before I start on the drivetrain. If I get it running I'll never finish the exterior.
I'm a little burn out on the camaro at the time. I still drive it alot I just haven't been sinking anymore money into it at the moment. When I get the mustang finished and on the road I'm thinking of tearing the motor back apart to lower the compression and going turbo. It may be a couple years away though. I figured it was time to explore a new car and engine platform.
Old 03-11-2011, 05:34 AM
skinnies's Avatar
On my rx7 I uesd a truck pan that we cut down and added a kick off to the passenger side to keep it 6 quarts so yes the pan can easily be modified. Also had to modify the pickup tube.
On my ltd(foxbody chassis), we built solid motor mounts on the stock kmember and put the motor high in the engine bay, I'm also using a stock truck oil pan with plenty of ground clearance. That is with the stock springs also and the car sits probably 1.5-2" lower than stock. Sorry I don't have any pictures for you.
Old 05-24-2011, 11:25 PM
1961ba427's Avatar
I know how that feels. Any updates on either of your projects? I still want to get that posi unit from you. I figured we'd all meet up at Cecil, GA sometime, but never heard when ya'll were headed up. I'm not opposed to paying for shipping....would be cheaper than the trip down to the track for me really. I'm in middle GA, so it's a little over 3 hours one way down there. I'd still have enjoyed going and meeting everyone.
Old 05-27-2011, 11:15 AM
82 Rustang's Avatar
Default Mounts
So I have found some mounts that basically mount a LS in a fox body using stock K member.
The lower is a 350 mount for a s10, the upper blockside is a three bolter Chevy mount. It looks like it will work with a number of different exhaust set ups. I am tempted to try it with some long tube 351 headers made for a fox.
The only mod is a cheater plate that needs to be made for the motor side of the mount.(Piece of Cake)
I am using a UPR K member but I am pretty sure they will work with even a stock k member.
Old 05-27-2011, 05:11 PM
9389coupe's Avatar
Any pics of the s10 mount setup?
Old 05-27-2011, 07:25 PM
82 Rustang's Avatar
Default Mounts
Here is what she looks like. Real simple ove the counter parts for the most part.
File Type: pdf
Quick Reply: Fox Mustang Budget Swap/ Motor Mount Questions
