Missing head dowel pin - options?
Old 02-19-2011, 12:09 PM
Glenn98ZM6's Avatar
Default Missing head dowel pin - options?
Should I replace it?
Will I be OK w/out it?
I need to put this motor together today and no one in town has a pin for an LT1/SBC.
Old 02-19-2011, 12:53 PM
RamAir95TA's Avatar
Yes you need it. Don't even think about not using it.
Old 02-19-2011, 05:06 PM
Village Troll
SS RRR's Avatar
Old 02-19-2011, 07:26 PM
defaultexistence's Avatar
having a brain fart... WTF is a head dowl pin?
Old 02-19-2011, 07:30 PM
Sublime Dak's Avatar
The small 1/4 dowels on the head surface of the block. They are mostly there to align the head gasket and help keep the head in position while assembling the engine.
Old 02-20-2011, 09:05 AM
96TransAmboosted's Avatar
you def need that, your gasket will blow out with out it. Seen this happen at work a few diffrent times over the year, all that work to just take it back apart. try a 4.3l v6 it should work fr you
Old 03-03-2011, 04:11 PM
spilner's Avatar
I have te same problem. I am missing one. Where can I order a couple?
Old 03-03-2011, 06:03 PM
myltwon's Avatar
just google "sbc cylinder head dowel pin"
Old 03-03-2011, 06:10 PM
WS Sick's Avatar
My o'reillies has them in stock.
Old 03-03-2011, 06:23 PM
jim ravencraft's Avatar
Hi,
the above post are correct......they are for alignment and strength.....
Never..........never......install heads without them.........good luck and have a truly blessed week..........jim
Old 03-03-2011, 07:08 PM
spilner's Avatar
thanks
Old 03-03-2011, 11:49 PM
fastburn's Avatar
junk yard,take visegrips
Old 03-04-2011, 08:48 PM
LOL your junk yard has 350 sbc? where is this at
Old 03-04-2011, 10:08 PM
RamAir95TA's Avatar
Millions of SBCs have been manufactured since 1955, and all of them use the same dowel pins.
Quick Reply: Missing head dowel pin - options?
