My take on MM Spacers for the rear
Old 02-15-2011, 12:05 AM
killernoodle's Avatar
Default My take on MM Spacers for the rear
I lowered my car but didn't like the design of the mightymouse spacers that I got CAD drawings of. The force is transmitted through 2 bolts into a .25" plate and it leaves a hole in the shock tower for crap to spray through unless you plug it up somehow. I decided to take it a different direction and weld a 1.5"x.095" tube onto the bottom plate and then weld a cap on that. It gives me the spacing I need without any of the drawbacks of the MM spacers, PLUS I didn't have to buy anything from the hardware store
They probably could have used a little paint, but I was in a hurry.
Sorry for the blurrypics, the camera on my droid sucks unless everything is perfect.
If anyone is interested, I can make a set for you no problem. I'd probably have them CNC plasma cut instead of hand plasma cut.
Attached Thumbnails My take on MM Spacers for the rear-img_20110212_182728.jpg   My take on MM Spacers for the rear-img_20110212_182734.jpg
Old 02-15-2011, 04:03 AM
itsslow98's Avatar
Not bad, but i dont see how anything is getting sprayed in there with MM spacers, you have the piece the bolts under the wheel weel and the bumpstop snugged up that. I just dont see how anything could get into the shock tower.
Old 02-15-2011, 08:25 AM
Fuzzy_Wuzzy's Avatar
I like it, the MM spacers work great, and i have no problems, but these seem simpler, and keep the upper mount stiffer.
Old 02-15-2011, 10:10 AM
DrSpeed's Avatar
I like it!
Old 02-15-2011, 11:00 AM
Eastern Regional Coordinator
CTSVBiggie's Avatar
aslready purchase but have yet to install my MM spacers. As long as they work I am all good.
Old 02-16-2011, 04:36 PM
ferny's Avatar
same here....i have had my MM spacers for over a year and have no problems what so ever.
but its always nice to have different options.
any pics of the ride after you lowered her?
Old 02-16-2011, 05:18 PM
JNR_Design's Avatar
I like your idea of keeping the plate closer to the clamping surface, so to speak. I bet those MM ones are OK [I won't ask how much they are though for such a simple piece ] with regard to the forces' direction, but still may as well eliminate that extra concern. I don't think I'll ever lower mine, but like the ideas!
Old 02-16-2011, 07:11 PM
itsslow98's Avatar
Yea the MM are a tad bit but they do come with nice bushings(starts with a P) and for the entire setup and springs its not a bad deal for the looks.
Old 02-16-2011, 11:42 PM
I'm probably going to end up making a few sets in a couple weeks. They will be CNC plasma cut from 1/4" steel, tig welded, and powder coated with all the hardware. I'll get a price nailed down and let you guys know.
Also, I'll take some pics of the lowered ride tomorrow
Old 02-17-2011, 12:16 PM
DrSpeed's Avatar
Nice....keep me on the list!
Old 02-17-2011, 05:17 PM
DrSzabo's Avatar
Please keep me on that list too..I am very interested in getting some more info
Old 02-17-2011, 05:31 PM
racebyu's Avatar
Nice design, looks real solid for the shock mounts.
Old 02-18-2011, 08:37 PM
supergeess's Avatar
Nice! Keep us posted
Old 02-18-2011, 09:00 PM
TheLAW's Avatar
Subscribed.
LAW
Old 02-19-2011, 10:35 AM
MIGHTYMOUSE's Avatar
Figure if you spot people a couple years and give away the the original design, there is bound to be innovation.
I used bolts and spacers to keep the pice down and make it adjustable. Either of the two 3/8 bolts are thicker than the shock shaft itself. This design here should get the job done fine provided the welds are strong and don't corrode or crack.
My original stuff was proven at the dragstrip, daily beat, and roadcourse before I started sharing out the design, and I still have never heard of a single issue thus far. I strongly reccomend that happen with this version as well to avoid issues/accidents.
Only thing I remember was an 'internet engineers' that decided to get people wound up about the plate thickness even though I had done my real world and FEA testing of 3/16 material. That drove me to step to 1/4 plate for absolutely no structural reason. I see this design not really 'needing' it either.
It would be easy to sandwich a piece of rubber in there to eliminate 'crap spray' but since its not actually a problem in real life, I didn't bother increasing the cost.
So I guess last thing as far as anyone considering a lowering fix is that I reccomend not making fix decisions based on speculation of a problem and concentrate on real ones. It is exciting to see new ideas tho!
Regardless get out there enjoying your car and a proper lower ride height
Old 02-21-2011, 07:54 AM
smbstyle's Avatar
+1 for anyone "concerned" about the durability of the mightymouse kit. I've absolutely THRASHED mine around one of the roughest road-courses in the states; Sebring, and have about 12 autocross events with the car running the MM spacer kit with H&R springs.
Old 02-22-2011, 12:26 AM
DrSpeed's Avatar
Where can we see more of these MM spacers then?
Old 02-22-2011, 09:25 AM
Old 02-22-2011, 10:56 AM
DrSpeed's Avatar
What other parts do you make?
Old 02-24-2011, 09:29 AM
BONESTOCKC5's Avatar
I'd be interested in a set also, keep me posted. looks good
Quick Reply: My take on MM Spacers for the rear
