Simple way to disable DoD?
Old 01-27-2011, 02:01 AM
LS1>girlfriend's Avatar
Default Simple way to disable DoD?
Is there a simple way to disable DoD?
I've searched but didn't come up with any threads saying how to disable this sometimes annoying feature. Can we get a sticky? This seems to be a fairly common question.
Old 01-27-2011, 03:22 AM
94ss06gxp's Avatar
unplug ur oil pressure sensor
Old 01-27-2011, 05:44 AM
Ill_Born_ss's Avatar
If there was a foolproof simple way, I would have written an article on it.
You are lucky to have an 06, recommendation would get yourself a DiabloSport Predator model U7191 or HIGHLY recommended TRINITY.
There are many,many benifits to this solution and plenty of threads of what it can do for you.
Old 01-27-2011, 07:42 AM
hazards280's Avatar
Unplug your variable effort steering?! We forgot to plug the wire back in after replacing my lifters and it would NOT kick in until I plugged it back in.
Old 01-27-2011, 09:06 AM
DavidGXP's Avatar
Dont unplug anything. Everything works together. Best bet is to buy a tuner. Sucks... I know, i just had to buy a hand held myself.
Old 01-27-2011, 10:55 AM
707chance's Avatar
Default Dod
I turned my off using a Diablo tuner. It takes about 3 minutes.
Old 01-27-2011, 11:16 AM
94ss06gxp's Avatar
take wire cutters to your dod connector
Old 01-27-2011, 11:30 AM
DavidGXP's Avatar
Dont muck with the dod connector! Your motor will get stuck in 4 cylinder mode!
Old 01-27-2011, 11:52 AM
Thanks for the replies, I'll be getting one of the Diablosport tuners before I get the headers. Sounds like I have to wait.
Are the people with DoD disabled getting less oil consumption? I'm under the impression DoD is why we,re using so much oil, is this true?
Old 01-27-2011, 12:02 PM
Sadden's Avatar
Spend the money on the trinity.
Old 01-27-2011, 12:10 PM
94ss06gxp's Avatar
i also noticed ( when my oil pressure sensor went out DOD was disabled) that when cruiseing my torque converter wouldnt lock and unlock like 2-3 times when cruising and it wasnt as touchy to unlock.
Old 01-27-2011, 05:52 PM
Kazmaniac's Avatar
Exactly - top driver side of engine under the throttle. My sensor failed also - will throw a code but will eliminate the DoD for free.
Old 07-12-2011, 11:12 AM
rvd9431's Avatar
Never saw an answer for this question, can you disable dod with a tech 2? That is the dealerships diagnostic tool.
Old 07-13-2011, 04:48 AM
Mikzgp's Avatar
No it cant
Old 07-14-2011, 03:51 PM
TML529's Avatar
I have an 08 GXP and Diablosport says that The Predator is not compatible so what are my options as far as disabling the DoD?
Old 07-14-2011, 04:38 PM
94ss06gxp's Avatar
ill quote my self,
but in all seriousness, find someone that can tune with hp tuners in ur area or send out ur pcm for a tune.
Old 07-15-2011, 09:25 AM
TML529's Avatar
Thanks for the info.
Old 11-11-2013, 10:21 PM
jsmith309's Avatar
Any damage yet?
Old 11-12-2013, 01:01 AM
neilownz's Avatar
I thought you could drive in 3 instead of OD, but this is an ancient thread. Save for a tune.
Old 12-04-2013, 09:08 PM
Kazmaniac's Avatar
Originally Posted by jsmith309
Any damage yet?
170k ...
Quick Reply: Simple way to disable DoD?
