No thermostat, no problem???
Old 01-22-2011, 02:35 PM
lncboytre_d's Avatar
Default No thermostat, no problem???
Is it ok to run without a thermostat?
I've been running without it. The car never rises above 180 and seems to be fine.
Old 01-22-2011, 02:51 PM
96lt1m6's Avatar
Not a good idea..... coolant just constantly circulates and will not get enough time in the radiator to cool off before it returns to the motor. You will eventually see especially when the warm weather comes......safe bet is to have a 160°-170° thermostat installed.
Why are you without a stat?
Old 01-22-2011, 03:04 PM
Car was stolen a while back and I just got it running, it was trying to overheat so I removed it, put it in a pot of hot water with no results. I had more work to do to the car so I left it out til I finished. I drove about 50 miles around dallas with it out through traffic. It never got above 180-185. Before I created a new problem I thought I'd ask.
Old 01-22-2011, 03:17 PM
whytryz28's Avatar
I ran around for 3 years in Florida weather without one in my 69 camaro, never overheated once.
Old 01-22-2011, 03:49 PM
idformula's Avatar
Another problem that can happen is the coolant will circulate too fast, it won't pick up enough heat throughout the motor, so it will run hotter than what the coolant temp is.
Old 01-22-2011, 04:02 PM
David21's Avatar
Are you serious? Wow ignorance at it's finest.
If it's not in the radiator long enough to "cool" than how can it be in the motor long enough to get "hot"? The same logic applies.
Bottom line is you will be absolutely fine the purpose of a thermostat is to help the motor get hotter quicker and stay in operating temperature when cold.
Again this is also an ignorant statement to make.
Old 01-22-2011, 04:10 PM
bowtienut's Avatar
You beat me to it. Those comments above indicate a lack of understanding of........call it what you want: basic thermodynamics, or just common mechanical sense.
Only in cold weather will you have a problem keeping enough heat in the engine. For engine longevity, fuel mileage, emissions, and heater/defroster functions, it's best to run a thermostat. I like 160 deg stats in the LT1's; with the reverse flow, the engine ends up running in the 175-180 range.
Old 01-22-2011, 04:23 PM
David21's Avatar
Thank you.
Im sorry for the way I said it if I offended the two above, but it irritates me when people spew incorrect information like that.
I can't say how many times ive already seen on here the misconception of,
"the water goes too fast through a radiator your car will overheat" garbage
Old 01-22-2011, 04:32 PM
Thanks for the help. More importantly thanks for explaining your reasons why or why not.
Old 01-22-2011, 04:36 PM
David21's Avatar
No problem just surprised they didn't say anything about your hi flow water pump lol.
Nice mod list btw, seems all your lacking are some gears
Old 01-22-2011, 04:45 PM
shbox's Avatar
There are big differences in the water pump and thermostat than in that car. You can't really compare the two.
What happens when you have no thermostat in an LT1 is that not all the heated coolant coming from the engine will make it to the radiator (it will go back into the engine). In the summer, this can lead to rising engine temps during higher ambient temps. In the winter, you may not notice, but you'll likely get more efficient warm up with it present (and that is a good thing for engine life).
The thermostat is not the same as an SBC thermostat and has a dual stage function and the water pump has complex passages to make use of it.
Bottom line-run a thermostat.
Old 01-22-2011, 04:49 PM
chaman's Avatar
Ive ha d a lot of cars without a t-stat and never a single problem. In colder weather it could in fact be a problem.
Old 01-22-2011, 04:54 PM
Gears will be my next mod....lol. I ran out of budget money. For that matter I went over budget a LONG time ago.
Old 01-22-2011, 04:55 PM
bowtienut's Avatar
What happens when you have no thermostat in an LT1 is that not all the heated coolant coming from the engine will make it to the radiator (it will go back into the engine). In the summer, this can lead to rising engine temps during higher ambient temps. .
true dat
If you really must run an LT1 without a tstat (I do for racing, so I can do a quick cooldown between runs), you need to plug that bypass passage to force it all through the radiator.
Old 01-22-2011, 04:59 PM
I'd like 3.73's but was leaning more towards 3.42's haven't deceided. Can't really justify one over the other. I don't race much, just like to go fast and sound good doing it.
Old 01-22-2011, 05:03 PM
It's slower than yours I know...... But its fast enough to out run the guy behind me
http://www.youtube.com/watch?feature...&v=oNxGJsGoFTk
Old 01-22-2011, 05:04 PM
David21's Avatar
Go 3:73. You'll regret it later if not
Old 01-22-2011, 05:05 PM
David21's Avatar
Sounds really good
Old 01-23-2011, 03:54 PM
It took just under 5 minutes to warm up at idle to 170. I let it idle for about ten minutes then adjusted the rocker arms which took another 15 to 20 minutes, the car never got over 180*. I was worried about it staying in open loop from being below normal op temp but it went into closed loop around 150-160. According to Ion at madtuner.com running a lower t-stat and fan temp allows for a more aggressive spark table. With that in mind the car should be fine without one I think. And the heater, does it work...... fells like its funneling heat directly from hell
Old 01-23-2011, 04:30 PM
formulafast's Avatar
think of it this way, no therostate less restriction more HP!!!!!! We should all do this lol
Quick Reply: No thermostat, no problem???
