69 GTO 5.3 4l60 swap
Old 01-10-2011, 06:55 AM
c6matt's Avatar
Default 69 GTO 5.3 4l60 swap
I've been working on a friends 69 pontiac to give it some ls power and hopfully better than 11mpg. Swap details
2005 5.3/4l60e for 2wd tahoe
F-car intake
2008 truck 5.3 water pump to clear intake
4th gen pace setter headers (gonna try and make them fit pass side trial fit showed 1 tube that needs massageing)
2002 f car swap harness
Bowtie overdrives trans crossmember
random ebay engine plates with prothane mounts
2002 f car radiator and fans
Before
New Engine..65K on it
Pulling out the 400
no turning back..
The staredown
Painting
Awaiting the engine!
Some pontiac blue on the valve covers (and coil mounts not pictured)
Going in!
She fits!
Old 01-10-2011, 07:34 AM
garys 68's Avatar
Is you using the LH8 oil pan?
What P/S pump pulley?
And I'm guessing you discovered the 05 TB doesn't clear the L92 water pump.
Old 01-10-2011, 07:52 AM
c6matt's Avatar
LH8 pan, and running the cable throttle body that came with the LS1 intake, never planned to use the by wire throttle, it clears with a little grinding..
a PS pully, that is the question, and is on the top of the "must find" parts...
Old 01-10-2011, 08:07 AM
garys 68's Avatar
I'm doing an 05 5.3 in a 72 442.
I got the 300-123 pulley, but it's not dished deep enough to align with the truck accessories without spacing the pump back. It works, but looking for a better alternative.
Old 02-22-2011, 01:28 PM
c6matt's Avatar
gm part #
10166335
Its a plastic pully... think its from a baretta/grand am... works great, over an inch smaller than the truck pully, all kinds of room now.. .
Old 05-10-2011, 08:54 AM
c6matt's Avatar
Its one wheel peel o terror...
Old 05-10-2011, 08:56 AM
c6matt's Avatar
Put down 282rwhp/310tq
http://www.youtube.com/embed/oKPTkLQ49m0
Old 05-10-2011, 09:04 AM
NOS327's Avatar
Inner tie rod to oil pan interference issues? Can you turn wheel lock to lock? Pics from forward underside please!
Old 05-10-2011, 09:09 AM
c6matt's Avatar
It was close, engine mounts were spaced up about 1/2 " to clear.and pass side zerk fitting was removed and a plug put in for clearance at full lock.. it was tight, but it fit.
Old 05-10-2011, 10:34 AM
Chicago TDP's Avatar
Is that the cruise control module on the fender well????
Old 05-10-2011, 10:59 AM
LILHOTROD96's Avatar
As the owner of two 69 GTO's this is pretty cool. Robbie and I are actually thinking of puttin as LS in the RAIII with with late model seats as well. The RAIV will stay original
Old 05-10-2011, 12:37 PM
c6matt's Avatar
yea, I did it on my 67 camaro, my buddy liked it so much he insisted I put it on his, its a 2001 S10 module
Old 12-02-2012, 06:35 PM
USNDV's Avatar
What is your new MPG?
I have a 69 GTO with a 461 in it.
I'm getting 7-8MPGs
Old 12-02-2012, 06:38 PM
oldgoat69's Avatar
Good to see another 69 here.
Old 12-02-2012, 07:05 PM
USNDV's Avatar
Default Thanks
I love your set up.
Are you only getting 282rwhp on you GTO?
What kind of mileage are you getting?
Old 12-03-2012, 01:46 AM
Orbitorange's Avatar
This thread is over a year old. Still glad to see it!
Quick Reply: 69 GTO 5.3 4l60 swap
