Trouble installing Infinity 62.7i
Old 12-24-2010, 12:25 AM
hisjakeness's Avatar
Default Trouble installing Infinity 62.7i
Hey everyone. Trying to install the Infinity 62.7i speakers in my door. I found the following install guide:
http://www.ls1.com/forums/showthread.php?t=29204
It says not to install the crossover that comes with the package. I have an aftermarket radio. I cannot get the speakers to receive anything but highs. I even tried every combination of wiring that is possible. If I hook up the stock speakers, the sound comes out fine. Anyone have any ideas?
Old 12-24-2010, 08:59 AM
Cheap Guy's Avatar
I'd check out the Monsoon FAQ and double check your connections. Hopefully you used the stock connectors which makes it a lot easier.
And when you get it done/fixed, let us know how they sound since they look like a good set to do the coaxial to component mod.
Old 12-24-2010, 09:06 AM
KEE AUDIO's Avatar
You've got the wires switched. You have the midbass wires on the tweeter which will be blocked and make no sound and you have the tweeter wires on the midbass which will make only highs coming from that speaker because it's filtered. I've done that before, years ago...
Old 12-24-2010, 12:41 PM
Thanks for the responses. I looked at the wiring and I'm pretty sure I had each one wired correctly. I even switched them around just to make sure and still got a very weak signal either way. It even seemed like there was a lack of power compared to all the other speakers. I'm baffled.
Old 01-02-2011, 11:47 AM
UPDATE:
Just got everything wired up and working. Had to go out of town for a week. Sorry for the late update!
Sound is good. Highs are crisp and the mids sound good. Definitely a good purchase (I got them for under $80 shipped). The fit was perfect.
Quick Reply: Trouble installing Infinity 62.7i
