5.3 bored and stroked to 383 and boosted 1000hp
Old 12-21-2010, 08:51 PM
turbocamaro125's Avatar
Default 5.3 bored and stroked to 383 and boosted 1000hp
I was thinking about getting a 5.3 block and using Callis 383 rotating assembly and boosting it to 900 to 1000hp. Can the 5.3 iron block handle this?
I have a ls1 block but I dont think it will last very long at this power level. I know the 6.0 block will handle this but 5.3 blocks are cheap and this is a cheap 1000hp budget build...lol
Old 12-21-2010, 09:22 PM
Anyone have any info??
Old 12-21-2010, 09:33 PM
9sectruck's Avatar
re sleeve your ls1 with some good sleeves and it will hold 900ish hp and still be 95lbs lighter
Old 12-21-2010, 09:35 PM
9sectruck's Avatar
o yeah when you do make a 1000hp it wont be cheap..... it wont take long **** breaks, its only as strong as the weakest link
Old 12-22-2010, 07:06 AM
I know it's not gonna be cheap cheap but I'm not buyin something I don't need. Basically can the 5.3 block handle that amount of power being a 383?
Old 12-22-2010, 08:34 AM
AgFormula02's Avatar
Are you talking about boring the 5.3 out to 5.7 specs and adding a 4 inch crank?
Old 12-22-2010, 09:38 AM
TGriz's Avatar
Yes. I have a 383 built the same way. Im planning on putting boost to it soon. maybe not making 1000hp tho.
Old 12-22-2010, 11:34 AM
yes 5.3 bored to 5.7 specs and throwing in a 4inch crank....it wont see 1000hp all the time just when racing a bike....basically a highway car
Old 12-22-2010, 11:39 AM
How much meat is left after the bore? I know it has been done for na, but not sure if the walls get too thin, specially for 1000 Hp.
Old 12-22-2010, 11:41 AM
IT_SS's Avatar
why not forged the 5.3? or Build a forged 346/7?
Old 12-22-2010, 01:11 PM
well 346ci would be harder to make the 1k, and spool up will be a bit slower. I had a buddy with a ls1 383 with around 800hp and was fine and is still running good, so maybe just use the ls1 with a 4inch crank and boost it, but I kinda want iron block tho for peace of mind...lol
Old 12-22-2010, 01:15 PM
AES Racing's Avatar
I think i'd rather build a 390, shorter stroke you end up with a stronger crank
Old 12-22-2010, 01:41 PM
IT_SS's Avatar
you can build an iron 347 out of the 5.3
Old 12-22-2010, 01:42 PM
so a 5.3 block with 3.89-3.90 bore and 3.75in crank? or are you talking about a 6.0 block?
Old 12-22-2010, 05:09 PM
Gingervitis Addict
slow67's Avatar
No, stock crank + bore out the 5.3 block to LS1 specs.
Old 12-23-2010, 02:41 PM
no i was talking about the 390ci, but AES racing what is the shipping on the 390ci turbo motor with callies parts?
Old 12-23-2010, 03:34 PM
AES Racing's Avatar
Our 390ci engine is 6.0 iron block, 4.030" bore, 3.825" stroke.
Shipping, $150 to a business throughout most of the country for a shortblock, Seattle WA is $200, highest price I've seen.
Old 12-23-2010, 05:32 PM
9 Second Truck Club
stock48's Avatar
Is the Ls1 bkock really that weak? I was looking one over the other day, and the cyl's seem to be pretty beefy and are siameesed.
Old 12-23-2010, 06:32 PM
9sectruck's Avatar
I have seen 800 hp on the flywheel with the ls1 with (darton sleeves) I think that is what they where called
Old 12-23-2010, 06:44 PM
That's a good price for that short block and shipped but I don't wanna built a ls1 block and have a cylinder warp or crack on me and wreck the motor
Quick Reply: 5.3 bored and stroked to 383 and boosted 1000hp
