low buzzing noise from dashboard
Old 11-30-2010, 07:34 PM
06gxp's Avatar
Default low buzzing noise from dashboard
ok on my gxp with the key on nothing else. there is this constant buzzing noise from my dashboad not real loud but its there. I thought maybe the noise would change if using turn signal or turn radio on and off. Same with blower motor nothing changes the pitch of the constant buzzing noise. Could it be a relay or somthing? I guess leave the radio turned up and never hear it lol. Anybody have similiar issue or fix? Oh yah the noise stays on when engine is running or not. Stops when turn key off.
Old 11-30-2010, 07:46 PM
LS1 Racing's Avatar
Edit: Is the sound coming from the speakers or under the dash? If it's from the speakers, disregard the stuff below, as I have no answers.
Our cars have little servo motors that operate the inner doors of the ventilation system. Normally, when they go bad, you get a clunk-clunk-clunk-clunk sound from under the dash under certain conditions. It's possible that one of the motors could have a gear completely stripped out and freely spinning.
There are two sets of these motors: One set under the dash in the driver-side footwell, closest to the center stack, the other set is located behind the glove box. You might want to listen closely to those areas to try and narrow it down.
Old 11-30-2010, 09:09 PM
texasGXP08's Avatar
I would bet it is your aspirator in the headliner, right in front of the driver's head. It is a little motor that senses air temperature for the HVAC system. That are known to get noisy, especially when it turns cold. In fact, try gently pressing in on the headliner, underneath the visor, and see if the pitch changes.
Old 11-30-2010, 11:44 PM
GXP25's Avatar
I thought the air temperature sensor was located right below the dash between the steering wheel and the ignition.
Old 12-01-2010, 05:31 AM
texasGXP08's Avatar
Yes, there is sensor there as well. I believe that all auto climate controlled Grand Prixs (probably all GXPs) also have an aspirator in the headliner. I have had mine replaced before under warranty for buzzing.
Either way, it should be easy to discern whether either of these two things are the culprit.
Old 12-01-2010, 09:01 AM
WhiteGXP313's Avatar
yeah i hear the same buzzing sound from under the driver side dash..... its pretty annoying when im just crusing around with no radio on
Old 12-01-2010, 09:09 AM
JP_GXP's Avatar
Monsoon buzz, probably. It's almost always the most simple thing...
Old 12-01-2010, 09:31 AM
94ss06gxp's Avatar
if you turn your car off and sit there for a few minutes does it turn off?
Old 12-01-2010, 11:42 AM
plmrass's Avatar
Anybody know where you can get a monsoon speaker on the cheap?? I know the one on the center dash is buzzing like crazy and its getting annoying. If I could get a good used or a new one cheap that would be nice. Anybody know where to get one. Thanks Jeff
Old 12-01-2010, 11:57 AM
vroom_vroom's Avatar
Just pick up an aftermarket pioneer off eBay there not expensive and pioneer has there sh*t on lock
Old 12-05-2010, 03:32 PM
christopher.lazaris's Avatar
I hea the same noise I always thought it was my keys or something rattlin in the glove box? Still haven't found the cause of it, also I been hearing a whistling sound as if my sunroof is open? Any suggestions on that?
Old 12-07-2010, 10:56 AM
well if your talking about the whistling sound when your going over 110 mph that whistle is from the windshield wiper
Old 12-07-2010, 11:13 AM
Hawkins04's Avatar
funny i have never heard that
Old 02-11-2012, 02:25 PM
crazyGXPguy's Avatar
Default any fix?
i have that same annoying noise. it sounds like its coming from underneath the dash, did any of yall ever get this diagnosed or fixed. it makes u wanna
Old 02-12-2012, 07:21 AM
twomorestrokes's Avatar
Both of our GP's with Monsoon stereo did this through the speakers. If that's where the sound is actually coming from it's normal.
Old 02-12-2012, 08:43 AM
Its not from the speakers its some electrical thing. I told the dealer that there was a buzzing sound coming from under the driver side dash when i had my warranty and they fixed it. Ill try and find the paper work for it tonight when I get off work.
The monsoons do give off a buzzing sound though, but the one from under the dash is something else.
Old 02-12-2012, 12:55 PM
Cully77's Avatar
I've got the speaker his too, but don't the SS's have bose?
Mine is only when the turn signal is on, or the radio is on with the volume very low.
Old 02-12-2012, 02:50 PM
I went to a local shop and they said it sounds like the aspirator, it goes into the dealership tomorrow for that to get fixed along with a bad strut or shock in the rear. Also two of the almighty monsoon speakers r blown and they will b getting replaced. I have only drove the gxp less than 2000 miles and I decided to check oil. What do ya know. Only 3 quarts low. Wtf! I'm going to have them install the new opg and hope that fixes that issue.
Old 02-12-2012, 07:56 PM
TML529's Avatar
Good luck with that. The dealer told me they had to do an oil consumption watch so I have to wait 3k miles in 500 mile increments for them to figure lo out what I already know
Old 02-13-2012, 12:13 PM
PurpleHaze9414's Avatar
Does anyone know the fix for the noise in the speakers?
Quick Reply: low buzzing noise from dashboard
