need some torque specs
Old 11-21-2010, 11:17 PM
super mario's Avatar
Default need some torque specs
I have a lq4 6.0 out of a 02 escalade and I need main cap torques and rod bolts..I'm using the stock bolts and the torque specs I'm findin are like 18ft lbs. And the last thing I want is to not tighten them down tight enough and throw a rod or something so can someone please give me the right torque specs...need them asap so I can put my engine together, thanks
Old 11-21-2010, 11:37 PM
TrippyJoey's Avatar
According to the LQ4/LQ9 Service Manual
Connecting Rod Bolts-First Design (First Pass) 20 N•m 15 lb ft
Connecting Rod Bolts-First Design (Final Pass) 60 degrees
Connecting Rod Bolts-Second Design (First Pass) 20 N•m 15 lb ft
Connecting Rod Bolts-Second Design (Final Pass) 75 degrees
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 20 N•m 15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees
Crankshaft Bearing Cap Side Bolts 25 N•m 18 lb ft
Crankshaft Bearing Cap Bolts (Outer Studs-First Pass in Sequence) 20 N•m 15 lb ft
Crankshaft Bearing Cap Bolts (Outer Studs-Final Pass in Sequence) 51 degrees
Quick Reply: need some torque specs
