TURBO LS1 BUILD help
Old 11-04-2010, 07:16 PM
LSXFORMULA99's Avatar
Default TURBO LS1 BUILD help
whats up guys.
Im building a forged ls1 347 with stock crank and 317 heads. victor jr intake.
fuel- 255 intank prolly inline booster pump with 60lb inj. water meth
Turbo- tc76 or 78 not sure
trans- th350 w/brake not sure on stall size
looking for the 9 sec zone on 15psi..
what would you consider to make it in the 9s.
Old 11-05-2010, 06:01 PM
anyone? tell me ur setup
Old 11-05-2010, 06:39 PM
Josh@KY-Turbo's Avatar
-Aim for rouhgly 9.7-10.2:1 compression
Fuel-
-Dual 255 intank
-80lb inj.
Turbo-
-TC78
-44-60mm WG
trans-
I prefer a TH400 but,
th350 w/brake 3000 Stall.
With good gas, a solid tune, and your planned 15lbs of boost, 9's should come easily.
Old 11-06-2010, 12:23 AM
cracker's Avatar
Fuel-
-Dual 255 intank
-80lb inj.
Turbo-
-TC78
-44-60mm WG
trans-
Engine -
8.8-9.5:1 Compression (JE Pistons, Decent Rods)
Fuel -
Agreed
Turbo -
Stay away from Turbonetics, Turbonetics = inefficient/wasted money
Precision 76HPS Billet Wheel/78HPS
WG = Turbosmart 40-50mm
Trans -
Depends on what you're doing but a glide is definitely better than any 350/400. Don't listen to the people who say Glides arent "streetable." They probably havent driven one/had one on the street. They are MORE streetable than a TH transmission...Fact.
With this, you will enjoy it way more than a 3 speed and a less efficient Tnetics.
Josh, no offense. I respect the work you do, but start using Precision Turbos, utilizing Powerglides with a Neil Chance converter and you will have happier customers and faster ET's.
Fact.
-W
Old 11-06-2010, 01:09 AM
I have multiple 7 and 8 second street cars running Turbonetics Turbo's . Not all of them are internet/LS1Tech jockeys. Sucks as the press is always good. At the end of the day I use Turbonetics, Borg Warner, Precision, Garrett, and several custom units. Its all about what the customer wants.
You are correct in the Fact that there are always better Turbo's, Tansmission's, Conveter's and so forth that will yeild better ET's. However those components are not always in the bugets of the customer. I make sure my customers get the best components that they can get with in thier respective budget.
Old 11-06-2010, 05:24 AM
yelo04goat's Avatar
Fuel-
-Dual 255 intank
-80lb inj.
Turbo-
-TC78
-44-60mm WG
trans-
sounds really close to my build..
forged 347 wiseco/eagle stock crank
ported ls6 heads custom cam
tc76
50mm tubrosmart BOV and wastegate
4l80 3400 stall.
kill mode will be 17+psi
9s really possible in a heavy GTO???
OP.. i would for sure be lookin at dual intanks..
keep us updated on your trip to ythe 9s... hope to be there soon one day!
hopefully we are on the right path!
im goin to more then happy running in the mid-low 10s but a 9.9999 is a 9 so i would be stoked for that..
Old 11-06-2010, 08:10 PM
what do u think about water meth? any of you use it?
going to see how far i can take the 60lb injectors.
Old 11-06-2010, 08:20 PM
MUSTANGBRKR02's Avatar
Meth is awesome!!
Old 11-06-2010, 08:33 PM
what does the size of wastgate matter?
Old 11-06-2010, 10:33 PM
yelo04goat's Avatar
if its too small you could have boost creep problems...
it may not be able to release all the pressure it need to if its tiny...
they can get pricy thats for sure... but there is always someone sellin used stuff its you want to keep on a good budget..
Old 11-07-2010, 08:39 AM
actually im not sure what size mine is..it came with the turbo kit. its a TIAL.
Old 11-07-2010, 07:12 PM
willizm's Avatar
Hey guys, don't mean to be hijacking the thread, but if you have easy access to e85, would you consider doing the conversion? from what I understand it's pretty easy with some 60lb or 80lb injectors and dual walbros. Just need to tune for it and makes sure you can supply enough fuel. Sounds like there is good returns on e85 and allows for more timing. Thoughts? I'm doing a single turbo setup this winter so I've thought about it since I have a couple gas stations within a mile of my house with e85.
Old 11-07-2010, 09:32 PM
yelo04goat's Avatar
if you want to make big power on e85 then you need huge injectors...
also just depends on where you are in the country..
e85 is all over the mid west... and its cheap...
out in the central valley of cali... i know of one pump station that has it... and thats out of a 50+ mile radius.
OP Tial makes good stuff and fairly good prices too.. just make sure its big enough..
Old 11-08-2010, 11:22 PM
bump...
Old 11-08-2010, 11:47 PM
smnitFB's Avatar
Sounds like a solid build. IMO just go with what you want and what will fit your driving style. You can always lose weight in the end to get where you want or upgrade compononents here and there. IMO it's all about matching the components to you, your car and what you want to do with it.
Old 02-03-2011, 08:57 AM
finally got my motor in. forged 370, solid roller turbo cam.
Old 02-03-2011, 08:59 AM
XtremeDime's Avatar
What about a rear?
Old 02-03-2011, 09:00 AM
i have a strange 12 bolt.
Old 02-03-2011, 09:03 AM
XtremeDime's Avatar
Are you sure it will hold up? I was told by alot of people it wouldnt, thats why I went with a Strange S60.
I suppose you are an auto, and I am a 6speed so that does change things
Old 02-03-2011, 07:12 PM
it will for sure hold!!!!!!!!!!! Just switched to a auto
Quick Reply: TURBO LS1 BUILD help
