White chrystally fluid under car
Old 10-27-2010, 06:56 PM
soontobeLS1's Avatar
Default White chrystally fluid under car
Noticed a dried up leak underneath my car...looks like acid on the concrete, kinda white and frosty and chrystalized. Looked under hood and couldnt really notice anything. I am guessing maybe freon??? I has my AC serviced back in August.
Old 10-27-2010, 07:55 PM
BOA279's Avatar
our cars dont have freon...they have R134 and its a gas. Almost positive you have discovered battery acid. Want to know for sure? Wipe it up with an old T-shirt....if it makes holes in the shirt then theres your answer!
Old 10-27-2010, 07:59 PM
LS6427's Avatar
Pull the battery out right now......you may have a disaster going on under it. I mean metal being eaten away for months.
Old 10-27-2010, 08:38 PM
bayer-z28's Avatar
^ Corrosion.. YAY!! And if your REFRIGERANT leaked on your AC the only way you would know is your AC wouldn't work.. and We actually have R-134a in these late model vehicles (94 and up, IIRC.)
Old 10-27-2010, 09:17 PM
so, pulled the battery....appears there is liquid on the positive terminal that came from the positive spot on the battery....i soaked the area with baking soda/water...lots of sizzlin!!! So it's def battery acid....I then sprayed everything with water after soaked with baking soda.....battery is being discarded for a new one....I hope I got everything....From the spill...looks like it just exploded one day.....I noticed the white marks on my cement last week....Anything else????
Old 10-28-2010, 07:29 AM
bayer-z28's Avatar
Time for a....
My battery puked a while ago but it was the vent tube that puked all over the side of my radiator..
Old 10-28-2010, 05:28 PM
LS6427's Avatar
Yes. Even though it looks all clean of acid.....get that spray foam that eats acid away and dissolves it and neutralizes it. Spray the **** out of everything, underneath the battery tray, everywhere.....if one tiny bit is still there it'll keep eating the metal up.
I got a 7yr AC Delco battery.....thats a long 100% warranty man. And the battery is a POWERHOUSE. I leave my stereo (1,000 watt amp) cranking pretty good for 2-3 hours while I polish my car and it does absolutely nothing to it.....cranks right up like normal.
Can't remember exactly, its posted here somewhere, I think it was around $100.00 with my old core trade in.
Quick Reply: White chrystally fluid under car
