power antenna won't go down
Old 10-15-2010, 10:44 PM
rxrom's Avatar
Default power antenna won't go down
The power antena won't go down in my 2000 trans am. Is there a fuse or realy or do I need to replace the antena. How hard is this job?
thanks
Roman
Old 10-15-2010, 10:47 PM
ULTIMATEORANGESS's Avatar
motor is probably shot. i dont have a power antenna but if its easy to get to it shouldnt be a problem replacing.
Old 10-16-2010, 08:23 PM
Save the manuals!
wssix99's Avatar
Does it make a sound when it tries to retract?
Old 10-16-2010, 09:06 PM
GSus's Avatar
I got tired of trying to fix mine. I just bought a new metco unit from auto zone...$50. Took all of 20 min to replace.
Old 10-16-2010, 09:34 PM
rxrom's Avatar
Doesn't make any noise.
Old 10-16-2010, 10:23 PM
00_Silver_Bird's Avatar
Mine was stuck up when I bought the car, replaced it with one off ebay, went up and down once...And once again I have a car with an antenna up all the time....Every once in a while I hear the motor working, but the mast stays up...
Old 10-17-2010, 09:58 AM
Save the manuals!
wssix99's Avatar
I'd check the electrical first. I would be surprised if the motor died on you. (Not sure which fuse is involved, though.)
Old 10-17-2010, 09:59 AM
Save the manuals!
wssix99's Avatar
You have a different problem. The mast is just gummed up. If you search, you should be able to find the method to clean it and get it working again.
Quick Reply: power antenna won't go down
