Buick Roadmaster LT1
Old 10-11-2010, 09:00 AM
RogueLT1's Avatar
Default Buick Roadmaster LT1
I found an LT1 for my 85 TA. The guy says it's out of a 94 Roadmaster and it comes with the full long block, all the accessories, the harness, the pcm, and the trans. So my question is, is there a difference between an LT1 from an f-body and an LT1 from a Roadmaster? If so, what are the differences? I thought I heard somewhere that if it wasn't from an f-body or a vette, then it probably has iron heads instead of aluminum. Also, should I use one from a Roadmaster or other non-sports car, or should I try to find one out of an f-body or a vette? Thanks guys!
Old 10-11-2010, 09:37 AM
RamAir95TA's Avatar
You first need to establish whether or not you have an LT1 or an L99. L99s are externally identical to LT1s with the exception of a few distinguishing marks. At the back of the block where it meets the intake manifold it will say either 5.7 or 4.3. If it says 4.3, stay away.
Old 10-11-2010, 09:43 AM
StangeatinZ28's Avatar
Exactly! be aware of this for sure
Old 10-11-2010, 09:47 AM
RogueLT1's Avatar
isn't the 4.3 a v6?
Old 10-11-2010, 10:01 AM
Joshiedoom's Avatar
What???? I have a 94 roadmaster wagon in driveway. It has the lt1 in it.... it is 5.7... l99 is a gen 4 engine...
Old 10-11-2010, 10:05 AM
RamAir95TA's Avatar
L99s are 4.3L V8s, not 5.7s. They are a variant of the LT1, still 8 cylinder, still V8, just with a smaller bore and shorter stroke.
What is a Gen 4 engine?
Old 10-11-2010, 10:11 AM
Joshiedoom's Avatar
You got to be kidding me right?
Old 10-11-2010, 10:16 AM
RamAir95TA's Avatar
The official "Gen IV" engine was released in 2005 as the LS2+ series. We're talking about an old Fleetwood.
Here's what I understand:
Gen I = SBC beginning in 1955 until 1991
Gen II = LT1, 1992 - 1997
Gen III = LS1, 1997 - 2004
Gen IV = LS2+, 2005+
You have me curious on what you're talking about.
Old 10-11-2010, 10:27 AM
RogueLT1's Avatar
ok, i'll be sure to check that when i go to look at it tonight. i didn't realize they made a 4.3 V8. Thanks for the tip.
Old 10-11-2010, 12:12 PM
Village Troll
SS RRR's Avatar
It's considered the "baby LT1."
Old 10-11-2010, 01:22 PM
porksoda's Avatar
All roadmasters got the 5.7.
Old 10-11-2010, 01:27 PM
WS Sick's Avatar
Thats some good info right there. =)
idformula's Avatar
close, the tbi's were just a gen I with fuel injection, and the vortecs are the same as the first gens.
Old 10-11-2010, 05:39 PM
96capricemgr's Avatar
The shortblock is the same as a f-body, the heads and cam are different but both are probably going to be changed if you are looking for performance.
It will have the later vented opti as the b-bodies got that in 94 with the introduction of the LT1.
As was covered the 94-96 Roadmasters, Fleetwoods and wagons(Caprice or Roadmaster) all got the LT1 standard. Guys here like to worry a LOT about the L99 BUT it was the base engine in the Caprice sedan only from 94-96, LT1 was optional for civilian or police cars and standard with the Impala SS TRIM PACKAGE.
Honestly when buying a 15yo motor I would probably rather have the b-body one because it is more likely well cared for than a beat on f-body or Vette one.
Old 10-11-2010, 05:56 PM
8595transam's Avatar
I used a lt1 from a 95 impala ss to put in my 85 TA. The under hood fuse box makes it really simple to do the swap. Pick up some gauges from a 86-92 car so you can use the elec. 145mph speedo instead of the mech. 85mph gauge that you have now. A little re-pinning of the harness but not that hard to do. try lt1swap.com for some wiring diagrams of the harness.
Old 10-11-2010, 06:42 PM
MasterTomos's Avatar
I think I know where there's some confusion here:
early/mid 90's L99= 4.3L V8 found in some b-body cars
Modern L99=6.2L 400hp V8 in the automatic 2010-present Camaro SS's.
The L99's offered in the 90's are in fact nearly identical to the 5.7 LT1's, all the above info is correct about them. They are not in reference to the modern 6.2L.
Old 10-11-2010, 06:55 PM
GM PHASST's Avatar
U might wanna find out if u may need offset motormounts for the swap. I found out the hard way when I swapped a lt1 into my 91 caprice.
Old 10-11-2010, 08:12 PM
It's a perfect fit in a 3rd gen. f-body. You will use your gen 1 mounts on the lt1 block though.
Old 10-12-2010, 07:25 PM
RogueLT1's Avatar
cool, thanks guys
Quick Reply: Buick Roadmaster LT1
