How long will a motor last with loose rod bolts??
Old 01-29-2004, 07:57 PM
AK's WS6's Avatar
Default How long will a motor last with loose rod bolts??
I was just wondering what would happen if you had loose connecting rod bolts?? Would the bolts over time work their way out and through a rod out the oil pan?? Or would it just spin a bearing?? Would it just start to knock and through a code if it were just a bearing. Thanks
Old 01-29-2004, 08:01 PM
MYTURBOT/A's Avatar
I threw a rod out the side of the block on a 1st gen 350 because of a torque wrench that was 15lbs lite on it`s calibration. So yes you will probly throw a rod.
Old 01-29-2004, 08:45 PM
AK's WS6's Avatar
Ouch that sucks!!!! Note to self: don't skimp when buying a TQ wrench.....Can you get to the rod bolts on a ls1 if you drop the pan???
Old 01-29-2004, 08:56 PM
tim99ws6's Avatar
TTT on that ??
Old 01-29-2004, 09:01 PM
Hugger SS's Avatar
Are you serious or is this a joke? ...Thats kinda like asking " I wonder what would happen if I only finger tightens my head bolts
Old 01-29-2004, 09:21 PM
AK's WS6's Avatar
Ha ha, well I must admit I was kinda serious, I knew all hell would break loose, I just wondered how long it would last.....like say 5mi under light throttle or right on startup or 1 quick WOT blast???? The only way to find these things out is to ask, or try it......soooo I asked, you see!!!!
Old 01-29-2004, 09:27 PM
MYTURBOT/A's Avatar
I had about 300mi on mine when it let go. wasn`t even broke in yet. you should be able to get at the rods if you pull the pan but to do that you probly need to drop the cross member.
Old 01-29-2004, 10:48 PM
slyws6's Avatar
I know a guy that replaced his pistons and rods by removing the crossmember from under the engine with the engine help up with a jack.
-Sly
Old 01-30-2004, 02:27 AM
Uthinkso's Avatar
Just pull her back out to be sure. This isn't something you want to play with.
I can't see it living much past your driveway if you had a loose rod bolt.
Old 01-30-2004, 03:20 AM
goober35's Avatar
Lets see. 3 days or so on down time. A little pocket change for a oil pan gasket.
OR
New block $600-1000 after mechine shop
New rods and pistons after market $1300 or so stock once will cost under 500 used but what is the point
New heads $200 or so for stock once.
Old 01-30-2004, 07:33 AM
Scott Turvey's Avatar
Cost to drop the crossmember and correctly torque the rod bolts - $0
Cost to rebuild engine when rod bolt lets go (depending on damage)- $2,000-$5000
Fessing up to, and posting a thread about a boo-boo like this - priceless
Old 01-30-2004, 11:09 AM
Nick Agostino's Avatar
TIME BOMB!! Even if it let go at idle there will be a big mess.
Old 01-30-2004, 11:16 AM
LS1TECH Sponsor
mikey's Avatar
Hey Nick, good to see you back here!
Old 01-30-2004, 11:25 AM
11 Second Truck Club
L-EATER's Avatar
I had a small block 400 come apart at 6500rpm because of a loose rod bolt when I was in high school. Just like a bomb had went off in the motor. There was NOTHING salvageable. The cam was broke into 7 pieces! I wouldn't advise running it if there loose.
Old 01-30-2004, 12:21 PM
bigoneZ28's Avatar
Talking
...good one
Old 01-30-2004, 06:01 PM
AK's WS6's Avatar
Ha Scott good one!!! You guys don't even want to know why I am pondering this question.........I just may be a very frusterated gent that is dealing with a horrible case of piston slap and Mr.Goodscrew won't fit the bill for what he fu#ked up and this particular gent who went out on a bit of a limb to afford his dream car don't want to eat the cost of a rebuild prolly not to far down the road!!!!
Old 01-30-2004, 06:21 PM
TeeKay's Avatar
389 Pontiac BB. Thought it was piston slap after hi-po rebuild. I was lucky, just cost $3,000 for a complete rebuild when the rod cap got twisted to a pretzel at idle. Don't even do it for 2 miles!
Old 01-30-2004, 06:39 PM
AK's WS6's Avatar
Man it seems yall have had some nasty experiences reguarding this subject!!!! I just hope GM will fix the motor so that guy don't have a story like some of these.
Quick Reply: How long will a motor last with loose rod bolts??
