Last edit by: IB Advertising
Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
- Camaro 2010-2015: How to Reset Check Engine Light
Step by step instructions for do-it-yourself repairs.
How do you reset the service engine soon light?
1. Turn key on but don't start car.
2. Pull PCM BAT and PCM IGN fuses in engine compartment.
3. Wait a few minutes.
4. Turn ignition off.
5. Replace fuses.
It will take the car a while to relearn the fuel and timing curves so don't worry about a temporary performance loss.
5. Replace fuses.
FYI,
every time you force DTC errors cleared you not only force PCM to have to relearn but you also just wacked all the onboard PCM I/M smog tests and some can take as much as 40 plus valid drive cycles to be back into a "Completed" passed state.
I suggest you let the error age out and clear by itself for then all the smog tests that were in a passed state still are.
Aging out may only take be like 3 drive cycles IF the problem has been corrected.
Originally Posted by TWISTA TA
What is the procedure for reseting the service engine soon light?
Try WWW.LS1camaro.net and look up SES in the search. Tried to copy and paste but could not get it to work..
WARNING: BAD TRADER STATUS
5. Replace fuses.
5. Replace fuses.
Thinks I used your method and it worked great. The code had come up because of a plug wire that wasnt secure.
