Which Oil Pump O-Ring?
Old 09-22-2010, 10:33 PM
Rick_Vor's Avatar
Default Which Oil Pump O-Ring?
I picked up what I thought was the correct Blue Oil Pump O-Ring 12557752 from the Dealership for a 1999 Silverado oil pump pickup tube for my forged 370 build. Once I got home I noticed my pickup tube had a recessed channel with a red stripe for the O-Ring. Should I be using the Red O-Ring on this pickup tube?
GM Oil Pick-Up Tube O-Ring (1st Design)
12557752
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
GM Oil Pick-Up Tube O-Ring (2nd Design)
12584922
RED SEAL
Specifics:
* Chevy/GMC Pick-Up (1999-2000 LS V8 engines with 2nd design pick-up tube)
* Trailblazer (2003-2008 With LS V8 engine)
* Hummer H2 (2003-2008)
* Hummer H3 (2008 With LS V8 engine)
* Chevy/GMC Pick-Up (2001-2008 LS V8 engines)
* W- Body (2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix)
* Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
Specs lifted from a posting by 69LT1Bird. :-)
Thanks, Rick
Old 09-22-2010, 11:05 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Yes you need the thicker o-ring for the recessed groove like that.
Most trucks also use that style, looks like a truck pickup tube also.
Old 09-22-2010, 11:29 PM
Rick_Vor's Avatar
Yeah, it's from a 1999 Silverado and the 370 is going in my 2005 Sierra.
Old 09-23-2010, 05:28 PM
MillsMotorvation's Avatar
I also was thinking, I got a oil pan kit from Summit, and the O-ring is Blue that came with the pan, and the O-ring that came in the stock pump(2002 LQ4) is red, will this cause a oiling problem? Also Im getting a new oil pump for the LQ4 will I need a new O-ring?
Old 09-23-2010, 06:51 PM
69LT1Bird's Avatar
You match the pickup tube to the O-ring. The oil pump bore is the same.
Old 09-23-2010, 07:33 PM
Ok, so Im good, thanks.
Old 02-14-2011, 02:34 AM
tiresmokinV8's Avatar
Sorry for bringing back an older thread but before I install the pan on a engine Im swapping into my truck I want to replace the oring. I picked up a oilpan and pickup tube off a new crate ls3 and it has a red o-ring on it. According to the chart above the vette should have the blue even though it only goes up to 08 but I thought the ls3 pans were the same as the ls2 ones. It came with a red oring and has an indent so Im pretty sure that it calls for a red one. The pan is going onto a ly6 which also had a red oring on the stock pickup tube, eventhough the oring is depedant on tube.
Quick Reply: Which Oil Pump O-Ring?
