Coolant Gurgling Sound
Old 08-27-2010, 11:52 PM
LSX Performance's Avatar
Default Coolant Gurgling Sound
I have a 02 Firebird LS1 and recently Ive noticed after driving the car there is a gurgling sound coming from the radiator and the sound of pressure being released at the radiator cap. Im wondering what is causing this?
I recently had the power steering pump replaced and my car has the factory ps pump cooler in the radiator. Do you have to drain the radiator to replace th ps pump?
Old 08-28-2010, 12:19 AM
fleetmgr's Avatar
I'd vote for a bad radiator cap.
Old 08-28-2010, 12:34 AM
LS6427's Avatar
You should spend the approx. $40.00 and 30 minutes of your time to get rid of that factory PS fluid cooler. All it can do is trash your cooling system when it starts to leak, and it will.
Other than that....as "flleetmgr" said.......sounds like you simply need a new cap. I've been using the Stant cap for the past 4 years with the pressure relief lever on it...$3.00 at PepBoys.
If that doesn't work....you very well may have a blown head gasket or some other pinhole leak somewhere thats letting air in after the engine is turned off and cools.
Old 08-28-2010, 08:31 AM
Save the manuals!
wssix99's Avatar
first thing is to replace the cap
Old 08-29-2010, 09:23 PM
joesscamaro252's Avatar
I've heard not filling your cooling system to it's maximum will cause a sloshing/gurgeling affect
Old 09-02-2010, 09:49 AM
andystaiger's Avatar
I too have this problem.. The weird thing is that I changed my ps pump too..
But it's only when I run the A/C, I will hear that gurgling sound AND THEN it will boil out of the top of the overflow tank..
I changed radiator cap, thermostat, checked to see if the fans were both operable..
And still nothing..
(just to maybe help eliminate some troubleshooting)
Old 09-02-2010, 09:53 AM
LSXFORMULA99's Avatar
my car did that after my cam swap. found out i didnt have enough coolant
Old 09-02-2010, 04:02 PM
00pooterSS's Avatar
ding ding ding
Also low coolant can cause a gurgle in the heater core too so you will hear it inside the car.
Quick Reply: Coolant Gurgling Sound
