Gen 5 Camaro Tuning, Diagnostics, Dyno results Tuning problems, solutions, dyno results for Gen 5 Camaro
295/312........
Old 08-27-2010, 03:43 PM
1320's Avatar
Default 295/312........
bone stock l99........mustang dyno. Last friday night there was another one at the track running 14.8's.
295 at 5500
312 ft lbs at 3700
af was 11.8 with oem tune.
Maybe the correction needs work, when its 110 degrees, and humid.
on the same dyno, a vortech blower car made 390......
Old 08-27-2010, 09:16 PM
LS1Tech Sponsor
06MonteSS's Avatar
those numbers are lowwwwww....
MY car's makin that
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 09-04-2010, 06:03 AM
ShamelessCookie's Avatar
Most Mustang Dynos are heartbreakers, I'm not surprised at all.
Old 09-04-2010, 09:34 PM
jeffreycastgsx's Avatar
Dynos are tuning tools, not a tool to measure power, every single dyno run will be different. Ambient weather such as temp, humidity, elevation all say as to what the number will be as well. Not to mention that the dyno can be manipulated to read higher or lower as well.
Old 09-05-2010, 08:22 PM
1320's Avatar
Dont get me wrong, Im not complaining. I'm a fabricator, and this car came in for a turbo system that we are using for out future kits. I just took the car to the same dyno I use all the time. I dont care what the number is, I use it for comparison. This was the base line. I did take the car back a day or two later to verify the results. With another 4-or 5 pulls, all were in the 294 to 302 hp area. Yes it peaked at 302 with 2 degrees of timing pulled via hp tuners.
Every car we put on this mustang dyno is "low" compared to every dyno jet the owners compare too. One of the last ones, was a scoggin dickey motor that was sold as a 545 hp 6.0......well it spun to 300 even....through a 4l80e.......
Old 09-06-2010, 10:57 AM
MikeG's Avatar
"Maybe the correction needs work, when its 110 degrees, and humid."
This.
As far as the track times go, well the elevation of LV is ~2028ft. When you factor in the weather conditions, the DA in the summer quickly goes over 5000ft.
Old 09-06-2010, 07:10 PM
MasterTomos's Avatar
yea mustang dyno's are not very accurate and extremely conservative. I remember seeing a stock LT1 making 190hp on one
Old 09-09-2010, 10:54 AM
Zombie's Avatar
FWIW i've tuned 20+ LS1 cars on this same dyno. This is my stock 98 A4 12 bolt rear tuned, then with a lid/filter installed and retuned, all done on the same day with minimal time between changes. All pulls started from same coolant temp.
Almost all bolt on 99+ cars I've done on this dyno make 290-320rwhp. Pulls are super repeatable with the error being +-1HP between pulls which makes seeing tuning changes super easy. Nothing beats a dyno like this for tuning. I think I ran a 14.4 at the track in it.
The sad truth is the new Camaro is a turd.
Old 09-15-2010, 09:30 PM
redsap05's Avatar
The l99 cars are turds from the factory. It sucks gm did this to all the guys want a auto tranny. My 05 a4 gto smacks around the a6 camaros at the track. My 13.0 to their 13.8 - 14.2. My gto was a turd as well and all I did was get a dyno tune. It really wakes up the car. The best advice I can tell you l99 guys is to get a dyno tune asap. In stock form the torque management will stop you from running a decent time. Its not the car at all.
Old 09-16-2010, 06:05 AM
Phil'sC5vette's Avatar
Mustang Dyno's are heart breakers on the number, but are great tuning tools.
Quick Reply: 295/312........
