Procharger D1SC w/ 3.85 pulley, 3lbs?
Old 08-22-2010, 01:14 PM
tictakman's Avatar
Default Procharger D1SC w/ 3.85 pulley, 3lbs?
Hey guys,
This is in a Florida climate...with a rough tune at the moment.
My setup is a 04' ls6 with a vindicator cam and supporting valve train, ls2 manifold and 90mm TB, 1 7/8 headers, 6 rib D1SC with 3.85 pulley and 6" crank pulley. I have a front mount ic, greddy type s bov with 3" ic piping.
I just installed the procharger and I am only seeing 3 lbs of boost.... I have disconnected the BOV to rule that out, didnt help still 3 lbs. I also pressurized my system to look for leaks up to 12 lbs and there were none. The belt is nice and tight with good alignment.
Do you think this is common with my setup? Should I run a smaller pulley to achieve 8-9 lbs of boost, if so what pulley? I will be upgrading to an 8 rib but i want to make sure this setup works before more money goes into it.
Any help would be appreciated!
Zak
Update
*************If you dont want to problem shoot and read through this post the issue was my font mount intercooler.************
Old 08-22-2010, 02:22 PM
Customizing Director
MadIceV8's Avatar
Same issue myself and I'm running a 3.4" pulley. I still have to check for leaks though.
Old 08-22-2010, 03:09 PM
tictakman's Avatar
haha, hopefully we can find out if its correct. I have searched through the forums to find a similar setup and the boost level achieved but havent had any luck. Im thinking/hoping its correct per altitude....
Ill call procharger tomorrow if i dont hear anything today.
Z
Old 08-22-2010, 07:56 PM
NoGo's Avatar
As a point of reference I made 14 lbs of boost at 5800 rpm on a 3.3 pulley w/ a 383 ci motor. I run 17 psi now on a 3.1 S/C pulley and 7.85" (I think) crank.
I ran a 3.85 6 rib for a short period and ended up changing it due to belt slip. Any belt dust?
Old 08-22-2010, 08:00 PM
01boydws6's Avatar
Is it possible your cam is causing boost to bleed off
Old 08-22-2010, 08:47 PM
tictakman's Avatar
not sure on the cam stuff but i dont have any dust on the mounts or anything. It seems to boost fine and quickly to that 3 lbs...just not more haha.
Old 08-23-2010, 05:48 AM
tictakman's Avatar
I wanted to add that I was previously turbocharged and didnt seem to have problems building boost then. I was at 4lbs of boost hitting 455 rwhp.
Z
Old 08-23-2010, 05:54 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
On a stock '99 Z28 with headers and exhaust, I saw 7 lbs of boost with a D-1SC 6 rib. Same 6.0 crank pulley and it had a 4.0 pulley on the head unit. I would think your cam is bleeding off several pounds of boost, but I'd say you should be seeing more than 3 psi of boost. I'd first rule out a faulty boost gauge. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-23-2010, 08:23 AM
tictakman's Avatar
I dont think its the boost gauge, I had a rear mount turbo right before this and was at 8lbs of boost which read correctly on a dyno tune as well. The power that the procharger is putting down feels like only 3 lbs as well.
The cam didnt feel like it was robbing power with the turbo application that I had on previously...
Old 08-23-2010, 08:44 AM
'Trust''s Avatar
That cam looks to have a least +10* of overlap, you are probably bleeding a lot of it into the valvetrain. You need a different cam.
Also, while you're at it, ditch the 6 rib. I had trouble getting my 8 rib to not slip even at 14psi on a 3.7" pulley.
You can't compare setups like that, CR, stroke, CI, heads, cam etc. all will change how much boost a car see's on a given setup. For example, I made 14.7psi on a 3.7" pulley, 20psi on a 3.4", and 21psi on a Riechard 3.1" on a 396 with the ATI dampener. Completely different to your results.
Old 08-23-2010, 08:48 AM
NoGo's Avatar
That's why I said point of reference.....
Point being his boost looks low.
Old 08-23-2010, 09:06 AM
'Trust''s Avatar
My point was you don't want the OP to put expectation on something based on what you made. His setup is completely different, and although it should technically make more boost on a smaller motor there are too many variables to provide a valid point of reference. Your 383 v. his 347 alone is enough to muddy the water. Just my .02.
Old 08-23-2010, 09:41 AM
tictakman's Avatar
Ill start searching for a good cam to go with on here and order one. I know there are a few people that make the 8 rib setup, do you suggest one over the other?
Old 08-23-2010, 09:46 AM
NoGo's Avatar
I prefer the SDCE. My advice would be to avoid a solid tensioner setup.
I went through a few different setups before finally settling on what I have now:
SDCE tensioner setup, ATI Balancer - crank pulley bolted to the front of it, Reichard Racing supercharger pulley. I run a napa belt, nothing fancy. This belt setup went 20k without any issues until the supercharger failed a few weeks ago and caused the belt to snap.
I sized a cam with -2 deg overlap. If I remember correctly the overlap numbers that they give you over the phone are at 50 thou lift, so a 0 deg overlap cap may **** through a little still....maybe someone else can clarify.
Old 08-23-2010, 10:08 AM
tictakman's Avatar
I appreciate the guidance, ill start ordering the 8 rib stuff this week!
Old 08-23-2010, 11:35 AM
'Trust''s Avatar
If you get a chance, check out ChevyChad's belt wrap fix (basically machining one of the stand-off's on the blower bracket and putting a pulley on it). Much more cost effective than the outrageous SDCE setup.
Old 08-23-2010, 01:05 PM
tictakman's Avatar
haha, i did stumble on that post! Ill check that out too since I wont have to spend much on that.
Can you explain why the cam could cause boost to "bleed" off? Is it leaving the valves open too long?
Old 08-23-2010, 01:13 PM
NoGo's Avatar
I would skip to the SDCE, but feel free to experment. Most of us have as well.
The overlap hangs the intake and the exhaust valves open simultaneously. In a N/A application this allows better scavenging of the combustion chamber of combustion gasses and helps to "jump" start the inlet tract velocity.
In a forced induction application the intake is at a much higher pressure then your exhaust so the scavenging overlap is either not needed or should be greatly reduced. Inlet air simply goes in the inlet valve and out the exhaust valve during the overlap. This bleeds your boost down, loads up your supercharger, and can result in a setup that has high parasitic loads on the supercharger, and low inlet pressures.
For the record though, I have never seen a setup bleed down to 3 psi of boost, but I haven't seen them all. I suspect other issues...probably in concert with your cam.... like belt slip.
Old 08-23-2010, 01:36 PM
'Trust''s Avatar
I never had a problem with slippage until I went to the 3.1, on the stock style manual tensioner. Which belts are you using? Gatorbacks were horrible for me, always had good luck with Gates.
x2 on the above. Thorough description.
Old 08-23-2010, 01:55 PM
1toofastlt1's Avatar
I have a lt1 with a vortech v1 kit. I was only getting about 2 psi and couldnt figure out why. there wasnt any dust around the pulley but I made a second tentioner to get better belt wrap. and just put a smaller pulley and now I see 6 psi. I have a 6 inch crank pulley and I went from a 3.33 to a 2.95
Quick Reply: Procharger D1SC w/ 3.85 pulley, 3lbs?
