Can you tap the LS1 valley pan for a PCV system?
Old 08-17-2010, 12:55 PM
4Birdman's Avatar
Default Can you tap the LS1 valley pan for a PCV system?
I'm in the process of planning out this 6.0L build, and I really am trying to make the engine bay as clean as possible by removing as much as possible.
I want to run some fabricated valve covers that don't have any vacuum fittings in them, which means I'm going to need to run some sort of PCV catch can setup.
I am wondering if it is possible to put a -AN fitting in the back of the valley pan and run lines up to a catch can hidden down where my AIR pump used to be.
And then can I just vent the catch can, and not have to run back through to the TB? I know I can run a breather on the valve covers, but I'd prefer to not have any breathers, just a small oil cap.
I guess I could also put some -AN fittings in the back of the valve covers and run them to a catch can, but if I can tap the valley pan and be done with it, that would be a bonus for me!
What do you guys think?
Old 08-17-2010, 04:35 PM
EricD's Avatar
Hi , i am pretty sure that can be done because i saw a valley plate cover that someone was using and it had been tapped , but it wasnt a homemade thing it was actually bought somewhere , i know what you mean about the small filters on your valve covers because this is what i did w,,ith my magnuson set up on my 4.8 pickup because i did not want to vent it back into the intake and gum up my supercharger , they look pretty old school on each valve cover but they work , i am pretty sure your idea will work afterall you are just venting pressure , if it is not thick enuf to tap you can use a bulk head an fitting with a seal washer, when i get around to it this is what i am going to do , Eric
Old 08-17-2010, 07:45 PM
Irish350's Avatar
you could use a normal slip fitting on your braided lined. Otherwise you could tap it for a fitting if you find one that has the flow you need and fill fit in that spot (under the tb?)
As far as just running a dirty line to a can with a breather, thats not how the pcv system works so it wouldnt do you any good. if you skim through this it has the diagram you need.
https://ls1tech.com/forums/generatio...outing-ok.html
Old 08-17-2010, 09:17 PM
Mumbles's Avatar
If you install an LS6 Valley Cover you can pretty much remove your entire LS1 PCV System. That's what I did when I installed my LS6 Intake and I also added a RevXtreme Catchcan.
I used the writeup on ls1howto.com. Here's a link...
http://www.ls1howto.com/index.php?article=18
Its not too difficult a swap. Cutting the piece out of the block that needs to be removed can be cause a little anxiety. I guess I'm not sure if the 6.0L Block would need this modification or not. Either way, its not as bad as it sounds.
Old 08-17-2010, 10:10 PM
09camaro383's Avatar
Agree with Mumbles just buy the ls6 cover I paid like 90 and it came with new gasket and bolts
Old 08-17-2010, 10:28 PM
4Birdman's Avatar
I don't want that **** running up to the throttle body, is there any way to just get rid of that?
The PCV valve is essentially a check valve, correct? It allows dirty air to leave without allowing any air to enter back into the system.
Couldn't I run an in-line PCV valve to a vented catch can, and not have to run anything back to the intake?
Old 08-18-2010, 08:21 PM
JasonSS2000's Avatar
There would be no way to draw or evac the harmfull combustion byproducts out of the crankcase. You must have a filtered fresh air source preferably on the oppiste valve cover as the crankcase evacs from. The intake manifold provides the vacuum to acomplish this. A good oil seperating can will not allow oil vapor to get through.
Do a search for: "is my catchcan routing correct?"
Quick Reply: Can you tap the LS1 valley pan for a PCV system?
