LS3 head chamber cc
Old 08-13-2010, 11:43 PM
richardp's Avatar
Default LS3 head chamber cc
Does anyone know for sure what the combustion chamber size is for the LS3/L92 head? Some publications say 70cc and others say 68cc. Also does any body know for sure how much I need to mill the head to get a 65cc chamber? I have read .025 and also read .030. Is the "rule of thumb" .006 per 1cc? I'm putting my LS3 heads on my LQ9 6.0 and I want to run 10.9 compression , same as LS2. thanks
Old 08-14-2010, 12:55 AM
AES Racing's Avatar
68cc is factory LS3/L92 chamber size
.006" per cc
Old 08-14-2010, 01:16 AM
VIPER EATER's Avatar
sorry bud dont mean to jack your thread here just curious,how much can you safely mill off of these heads? i have -12cc pistons with untouched 821s and the power just isnt there, thinkin of millin this winter. would like to get to 11.1-11.5.1 can this be done with milled heads and a thinner gasket than what im using now?(.051)
jason
Old 08-14-2010, 01:51 AM
Pwebbz28's Avatar
I remember reading they are 68cc chambers
Old 08-15-2010, 09:23 AM
TransWS6Am's Avatar
weird they had to take .014 off my ls3 heads to get 68cc
Old 08-16-2010, 10:10 PM
richardp's Avatar
Default chamber size
Most reports I've seen says 70cc, and to get to 68cc you need to mill .012, and for 65cc you need to mill.030. I guess when I take my heads to the machine shop I'll get them to measure the cc first, then mill them .012 and measure again, then mill .018 more (.030 total) and measure again, then we will know for sure.
Old 08-17-2010, 05:27 AM
69LT1Bird's Avatar
The factory blueprints show 68.4cc +-1 cc for the L92 heads. Mine came in at 68 cc in stock form.
Old 08-29-2010, 12:59 AM
richardp's Avatar
I took my ls3 heads to my machine shop friday to have them cc'd then milled and cc'd again, should have them back in a few days and will post the results.
Old 08-29-2010, 09:31 AM
LSX Mechanic
Damian's Avatar
Stock is 68cc give or take 1cc. A good porter can mill them .020-.030, sink the valves a tad and you'll still have some decent PTV clearance.
FWIW, I've done a 223/235 115 on LS3 castings cut .030. Had .060 intake clearance and .080'ish exhaust. Runs good.
Old 08-29-2010, 05:15 PM
bozzhawg's Avatar
Originally Posted by Damian
Stock is 68cc give or take 1cc. A good porter cam milled them .020-.030, sink the valves a tad and you'll still have some decent PTV clearance.
Cuttin it close I see....
duals or behive springs?
Looks like the LSL lobes
Old 09-04-2010, 10:12 PM
richardp's Avatar
Default chamber cc
Ok, I got my heads back from the machine shop, stock chamber size was 68.5 cc, they then milled them .030 and the chamber size is now 63cc., stock LS2 has 64.5 cc heads and flat tops and 10.9 compression, my engine should come in about 11.1:1 compression ratio, engine is LQ9 6.0, flat tops. thanks for all the input guys,
Old 09-05-2010, 12:50 AM
LSX Mechanic
Damian's Avatar
Close is fine if you've got a light weight valve and good spring. In that type of scenario I'll run them .050-.060 clearance on the intake without any worries. Those springs were "PSI" springs. Single beehive and will hold .650 all day.
It is LSL lobes. Those lobes work real well with the LS3/L92 heads.
Old 09-05-2010, 01:07 AM
spanks13's Avatar
Is there any worry about intake port seal cutting so much off the head?
Old 09-05-2010, 06:17 AM
69LT1Bird's Avatar
No, milling .030 off will not cause intake to head sealing issues.
Old 09-05-2010, 10:52 AM
bozzhawg's Avatar
Cool, what kind of power did that combo put down?
Old 09-05-2010, 11:56 AM
LSX Mechanic
Damian's Avatar
Not sure. We don't dyno too many cars @ my shop. They're built/tuned to be fast on the street, not the dyno.
Old 09-06-2010, 08:58 AM
redsap05's Avatar
So wouldn't you better off to try a thinner cometic gasket first instead of milling? That way if your cam doesn't fit no harm done, afterall you cant un-mill your head.
Old 01-19-2014, 06:09 AM
RezinTexas's Avatar
sounds good, I get 10.8 - 11.2 SCR depending on your piston to deck height.
Quick Reply: LS3 head chamber cc
