Lucas oil Transmission stop slip
Old 08-10-2010, 03:15 PM
06impyss's Avatar
Default Lucas oil Transmission stop slip
i was wondering if anyone has ever tried this stuff out and if it actually works. ive read many reviews saying it works good, and ive read many reviews saying that all it does is gum up the whole transmission pan. i am looking for anyway to save my transmission considering the trannys in the impalas have a tendency to have problems, and mine has been whining for quite some time now in 1st gear
Old 08-10-2010, 03:36 PM
Hawkins04's Avatar
dont worry its not just the impalas with the tranny problems. i had a friend that swore by it but i have never used it personnally
Old 08-10-2010, 05:56 PM
2005gxp's Avatar
ive used it in my car, tranny was slipping one day, changed fluid and added lucas hasnt had an issue yet(knock on wood!!!)
Old 08-10-2010, 06:27 PM
LS1 Racing's Avatar
Lucas oil won't stop your converter from coming apart, which is the main reason our trannys "go bad".
Old 08-10-2010, 06:50 PM
Hawkins04's Avatar
nothing will stop them from coming apart other than not driven them. they will sometime or another
Old 08-10-2010, 10:50 PM
06impyss's Avatar
is the converter the part causing the slight whine sometimes when starting from a stop in first gear at slow speeds?
Old 08-10-2010, 10:51 PM
06impyss's Avatar
how much of it did you put in your car when you changed the tranny fluid?
Quick Reply: Lucas oil Transmission stop slip
