Knock Sensors - Intake off, should I replace??
Old 08-04-2010, 06:35 AM
SS Brandon's Avatar
Question Knock Sensors - Intake off, should I replace??
While I have my intake off of the car, should I replace my factory knock sensors with a pair of new GM sensors? My stock units are working perfectly but I have 95,000 miles on them. I would hate to have to open her up again in 20K or so. What is the life expectance out of a set of these factory sensors?
Any help appreciated.
Thanks.
Old 08-04-2010, 01:28 PM
djfury05's Avatar
theres no reason to replace knock sensors if they are working properly
Old 08-04-2010, 01:48 PM
PontiacFan's Avatar
Insurance is cheap. Repairs later are not.
So there ya go, yer at 50/50.
Old 08-04-2010, 04:06 PM
TA98LS1's Avatar
replace them now, wont have to worry about them later.
Old 08-04-2010, 04:25 PM
redbird555's Avatar
id replace them and hindsight for me is 20/20 lol aftermarket sensors were goin out every few months on my car got ac delcos and all is well. knock on wood lol
Old 08-05-2010, 06:11 AM
SS Brandon's Avatar
How about the harness that attaches to them? Mine look pretty good considering they are sandwiched between the intake and valley cover. Should I consider replacing it as well?
Old 08-05-2010, 07:33 AM
redbird555's Avatar
thats entirely up to u unless its burnt i wouldnt mine is still ok i just checked it with an ohm meter when i replaced my sensors to make sure i had a good circuit.
Old 08-05-2010, 11:34 AM
BOA279's Avatar
I'm with everyone else...if your already thinking about it just do it now and not worry. If you don't you'll be doing the daily "I should have..."
Old 08-05-2010, 08:24 PM
Starion's Avatar
Do they look corroded or anything from water when washing the engine bay? Unless you have a 1998 (which had notoriously sensitive knock sensors) there's no reason to replace them. Save the money for performance upgrades.
Old 08-05-2010, 08:26 PM
Formerly 99-2door-08/30/2010
PitchblackC3's Avatar
Just pull the boots off and look at the sensors. Any signs of corrosion replace them. If not seal the boots with silicone and call it a day.
Old 08-05-2010, 08:37 PM
PontiacFan's Avatar
From the looks of the sig, ..., I don't think it's a money issue, ...
Old 08-09-2010, 08:58 AM
SS Brandon's Avatar
Yes, I have a few toys that I have collected over the years. But I always build and purchase on a budget. I'm **** that way. I figure that I can save a buck or two here or there (easy if you commit to doing the work). And believe me, it all adds up in the end. I always research extensively; this way I can buy right and most importantly, BUY ONCE!!!
Thanks to this board (and many other similar forums) and its members, I have been very fortunate with my purchasing decisions. Be it new components from supporting vendors or used parts from the classified section. There is tons of useful information available if you weed through the crap, because everyone seems to take the time to help and that kind of input from others personal experience is priceless.
Thanks to all that replied.
Old 08-09-2010, 09:37 AM
SS SLP2's Avatar
If I changed the sensors I would also change the harnes, do not use any thing on the threads, tork them to specs, seal around the rubber caps with silicon and build a bridge 1/4" high around the plugs with silicon- leave the bridge open on the rear. I lay a
cover of saran wrap of something over the top of bridge so that it will not stick to bottom of intake
just my .02
Johnny
Quick Reply: Knock Sensors - Intake off, should I replace??
